Won't agitate - free wheels - Washing Machines
    President:
  • 1,136 Answers
Hi, Is this a 1 or 2 piece agitator? If I had the model #, I could look thisup and assist you further.
Vic
Posted on Jul 03, 2009
The car won't go forward or backward
Lift up all the wheels one by one, rotate each wheel and check which wheel resists to rotate. Disassemble the jammed wheel and carefully examine to see why is it so.
Grease the caliper pins, free up the pistons and reset the brake components.
Dec 03, 2012 | 2001 Toyota Echo
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Won't spin
If a washer will agitate and wont spin check the lid switch. Lid switches are designed to not allow spin on most washer but will allow agitate. Safety feature.
If you need further assistance please feel free to comment me back.
Jul 27, 2011 | GE WBSR3140DW Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool GSQ9632LW0 problem
looks like the agitator dogs are broken. these are the pieces between the bearing and the top of the agitator. since this agitator is a 2 piece, you can just replace the dogs.
go to www.whirlpoolparts.ca and put in your model #. it will give you a parts breakdown.
hope this helps.
c
Sep 23, 2008 | Whirlpool AWM6120 Front Load Washer
Removing bolt in agitator arm
The bolt unscrews counterclockwise. Hold the agitator by the bottom vanes. If it won',t budge try tightening it first, just a little to break it free.
Dec 10, 2007 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
