Question about LG 24 in. LDS 5811 Built-in Dishwasher
My LG LDS5811ST has error code of IE Where do I
My LG LDS5811ST has error code of IE Where do I start?
  • 784 Answers
1-Check if the water Inlet Hose is kinked.
2-The Water Pressure is very low.
(below 10 psi)?
3-Inlet Valve is OK?
The filter of Inlet Valve is clogged
by water filter?.
The Impeller of Air Guide is bound
Posted on Jul 04, 2009
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
LG error code number 6?
Check your solution here:
http://www.manualowl.com/m/LG/LDS5811ST/Manual/296839
Dec 05, 2012 | LG 24 in. LDS 5811ST Stainless Steel...
Lds5811st won't drain error le
have to change control board on lds5811st water not draining on last cycle already changed pump
Nov 17, 2012 | LG Dishwashers
I have a LG Dishwasher Model LDS5811ST. The code
Did you find anything out? Mine won't drain either.
May 14, 2010 | Dishwashers
I have and LG nodel #LDS5811ST and after ad couple of minutes it stops with the code LE showing in the time window, what does this mean!
The wire harness has probably degraded and broken inside the door panel of the unit.
This unit may need a new wire harness, Main PCB, Sump and inner door liner.
Depending on serial#
Contact LG @ 1 800 243-0000 they may help you out.
This is a known issue on older dishwashers.
Jan 14, 2010 | LG Dishwashers
I have a LG diawsher, model # LDS5811ST that is
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
LE means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
You also should remove the door panel and check for a broken wire (usually the blue one)
If all the wiring checks out - it is most likely a broken or locked up impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | LG Dishwashers
Error code LE shown on a LG dishwasher model LDS5811ST and this code is not given on the standard error code list.
Hello JA12345,
Here is a link to the service manual for your dishwasher. Page 25 discusses the error code...
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Hope that helps you resolve your problem..
Regards,
Rick
Dec 13, 2008 | LG Dishwashers
LG dishwasher Model: LDS5811ST getting error code: 0E
OE is a drainage problem...check for twist or obstruction in drain hose .. make sure filter screen is clear... Hope this helps..
Sep 17, 2008 | LG Dishwashers
LG Model LDS5811ST error code LE
LE is a motor problem.. You can find details in the service manual at this website link... http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Page 25 discusses that error code and possible solutions
Hope this helps...
Sep 06, 2008 | Dishwashers
LG 24 in. LDS 5811 Built-in Dishwasher Logo
609 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
