GE Flat Panel Webcam #9865 "Error 0: Cannot create a video captur
I have a Flat Panel Webcam model #98665, I have lost the installation disk. I installed the driver for a Flat Panel Webcam model #98656. When I go to the AMCAP program on my computer and try to connect the device I get "Error 0: Cannot create a video capture filter". I have checked my USB ports and they work fine, the camera is lit up as if on. Please help!
  • Carolllin May 11, 2010
    Install CD
    Scholar:
  • 35 Answers
Ok, the first part of this problem you created when you installed the wrong driver! All bets are off when you do that and more times than not, it fails to work. I have the 98656 model (got it at the Flea Market for $5, and it works great!). You have the model 98665. Though they look the same, they are different. Follow my suggestion below and you should be back to normal in less than 30 minutes.
Okay, you could go threw all the things Bud said but it will take you a lot longer than what I'm going to suggest. Bud is wrong about having to set up all those other programs first. Why? Because before any of those other programs can "see" the webcam, Windows has to "See" & "Use" it FIRST. Then it will be available for any other program to use. Sorry Bud, but correct info is better than learning the hard way. Your way seems painful and wastes a ton of time.
You can simply uninstall the device (Right Click on the device in question and click Uninstall) from the Windows Device Manager, NOT Add\Remove Programs (we really don't need to remove the programs that are already installed, we just want to remove the hardware device itself and the drivers). There will be 3 items that will be removed: A USB Audio Device and a USB PC Camera with Mic.and a Composite Video Device.
Once the device is removed from the device list (the Tree) unplug the device and reboot your computer to clean up any leftovers.
Still with me? Good!
After you restart your computer, go back in to the Device Manager and double check the tree under the Imaging Devices & Sound Video and game controllers. You shouldn't see any USB PC Webcam stuff or USB Audio devices there now.
Now, just plug the device in. Be sure the port you are plugging this camera in to isn't on a USB Hub! The camera requires more power than a passive USB Hub can provide. Plug it into a USB port on the computer . If your USB hub is a "Powered" (meaning, it has a 5Volt wall-wart plugged in to it to provide more Electric Current (amps) to the hub), you can plug it in to the hub AFTER you've followed through with the video tester. A "Found New Hardware" window should pop up. When asked if the "Updater can check Windows.com for updates for this device?", just check the "Yes, this time only" option. Accept the rest of the default settings and click next. The updater should find the drivers and proceed with the installation. Ta Da! Your Webcam is installed!
Now, to test it, just open Windows Movie Maker (nothing to download, it's already installed in your system.
Go Start > All Programs > Windows Movie Maker to start the program.
Then just click File > Capture Video. The "Choose Your Video Device" window should open for you. Make any adjustments you might need (I'd just accept the defaults for now and click next 3 more times to get to the capture screen). Then see if you can see yourself on screen, If you do, you're 95% done. Now just record a few seconds or minutes of video with audio. Click the "Start Capture" to record a video and "Stop Capture" If you can do this then your camera is back to normal. NOW GO SET UP AIM or SKYPE or whatever you want, you should be good to go for all of them because Windows can "See" the camera and "Use" it!
I know this sounds like a lot but it's really not. This should only take about 5 to 15 minutes to complete.
Good Luck and let us know how this solution worked for you. It works for me. I'vr installed it this way on 3 very different computers and my Gateway Laptop. It worked flawlessly every time!
Again, Good Luck and keep us updated on your progress.
-=DrG=-
Posted on Jan 24, 2010
    President:
  • 8,637 Answers
Copy this web site and paste it in your web browser to get the GE PC Cam Drivers
http://www.jascoproducts.com/support/software-downloads.asp
Then to use it on the Web, do this.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Posted on Nov 20, 2009
I dont have the disk for my web cam GE 98090 how can i get the driver ?
It says that it doesn't need a driver since it follows a universal driver included in windows. GE Perfect Image Webcam (1.3 Mega Pixels) Our Products: GE Computer Accessories > GE Webcams 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg2.jpg GE Perfect Image Webcam (1.3 Mega Pixels) (Click to see larger image and other views) hs.align = 'center'; hs.transitions = ['expand', 'crossfade']; hs.outlineType = 'rounded-white'; hs.fadeInOut = true; hs.dimmingOpacity = 0.3; //hs.numberPosition = 'caption'; if (hs.addSlideshow) hs.addSlideshow({ slideshowGroup: 'slides', interval: 3500, repeat: true, useControls: true, fixedControls: false, overlayOptions: { opacity: .75, position: 'top center', hideOnMouseOut: true } }); function pcf_initEnhancement(ele,img) { if (document.getElementById('1')==null) { hs.expand(ele, { src: img, minWidth: 250, minHeight: 250 }); } else { document.getElementById('1').onclick(); } } SKU: 98090 Capture clear videos and sharp images with the GE Perfect Image Webcam. More details... Price: $54.99
icoaddtowishlist.gif icotellafriend.gif addthis_pub = 'jascoproducts'; addthis_brand = 'Jasco Products'; addthis_options = 'favorites, digg, delicious, myspace, facebook, google, live, furl, reddit, twitter, ask, technorati, stumbleupon, more'; icobookmarkshare.gif Product Details Capture clear videos and images photos with the GE Perfect Image Webcam. Capture high quality hands-free audio and broadcast through the built-in microphone. The stand can easily be adjusted to your desktop or clipped to your laptop or monitor. Complete with ArcSoft® VideoImpression™ and PhotoImpression™ editing software to capture, edit and customize images and videos.
Features:
  • Built-in microphone
  • Snap shot button - Easy to use for great still photos
  • Hassle free focus - Ensures crystal clear videos with adjustable focus ring
  • ArcSoft® Editing Software (Included)
  • Adjustable stand - Steady base ensures stable videos
  • Compact size - Provides convenience and portability, perfect for travel and laptop use
System Specifications:
  • Sensor: CMOS with 1.3 MP
  • Resolution: up to 1280x1024
  • Video frame rate: 30 frames per second
  • Color depth: 24 Bits, RGB True Color
  • Focus range: 10 cm -- infinite.
System Requirements:
  • Computer with USB port
  • 350 MHz recommended
  • 64 MB recommended
  • Windows® XP SP2 or Vista
  • 100 MB free hard drive space
  • 16 bit video display or higher
  • CD-ROM Drive
  • Universal Video Class no drivers
Nov 12, 2010 | GE 98090 Webcam
Web cam showing error 8007045a cannot create video capture filter
Problem for Logitech QuickCam Sphere Webcam Web cam showing error 8007045a cannot create video capture filter
Jun 22, 2009 | Logitech QuickCam Sphere Webcam
Error 8007045a: cannot create video capture filter. I get this error when i have installed the google video and chat. i have an INTEX IT-305WC night vision camera. when i go to devices in the camera exe...
I have windows xp and my web cam is pc camera 120 when I opened webcam nothing is displayed on the cam. It is displaying black screen. When I selected google camera adopter it is displaying 8007045a error. How can I solve my problem.
May 15, 2009 | Computers & Internet
MiniCam Pro 98067 help
I
lost the cd instalation for my minicam(pro) Model#98067
How can I install de cam in de pc?
Oct 23, 2008 | GE MiniCam Pro HO98067 Webcam
Getting code error 80070005 can not start graph
You can reinstall the Ampcam and the driver of Webcam. After restart try again. Also you can try some 3rd party software such as Webcam recorder that you can obtain from http://tinyurl.com/5sjy2l
Good Luck
May 31, 2008 | Philips J44414
GE Minicam Pro HO98067
just put the usb cabel in and then it will come up in my computer that you have put a usb cabel in open that folder and it will say web cam and it will atuomaticly open your web cam
Feb 13, 2008 | GE MiniCam Pro HO98067 Webcam
Hp officejet d145 multifunctional - lost installation disk
find a driver for the ge easy cam and download it,should work then i had samne problem..gl
Dec 19, 2007 | GE EasyCam Webcam
From GE
I misplaced my CD with software and drivers for my webcam. How can I get a replacement?
I have lost my software but I do not live in the US or Canada.
You will need Adobe Reader (free) to read the manuals
If needed, use the following link and click Get Adobe Reader
http://www.adobe.com
If you would like to download drivers and a manual sooner try
http://www.jascoproducts.com/support/software-downloads.asp#pccams For those interested in Vista see the following
From GE
http://www.jascoproducts.com/support/vista-certified-products.asp
This may provide additional information -- read this even if the message is not applicable -- it also contains information about non supported camera versions.
When I try to load the driver for GE PC Camera on my Vista operating system, it gives me the following message: Do you want to search for a driver?
Nov 21, 2007 | GE MiniCam Pro HO98067 Webcam
Computers & Internet Logo
1,319 people viewed this question
David Payne
David Payne
