Question about Velocity Micro NoteMagix x30 Laptop
Wireless connections won't connect!!!!
So i have the velocity mini notebook and just this week it started acting up it shows up my wireless connections but now it doesnt connect to any of them it starts connecting and then says unable to connect ive had it for a month and until now am having this problem what do i do??????
    Scholar:
  • 70 Answers
Make sure if your using WEP or WPA or NONE if the wireless router has a security like WEP or WPA make sure you enter the right WEP KEY or WPA key if ask on your computer take a look for your wireless router setting and wireless setting on your computer meets and same..
or
might be on your ADSL or what ever line you have try contact your ADSL hotline or what ever Line you use might be they had connection problem
or
try using LAN if working. if not your ADSL Line or what ever Line you use is the problem
Hope it help you out ^_^
Posted on Jul 03, 2009
Dell Inspiron Mini won't connect to wireless- won't ask for wireless password and therefore cannot connect. Help!
Learn easy Steps To Set-Up A New Dell Inspiron mini. If you need assistance with issue, Call immediately -18002044427 Dell Laptop Technical Support number, Read More http://www.delltechnicalsupportphonenumbers.com/blog/steps-to-set-up-a-new-dell-inspiron-laptop-for-the-first-time
May 08, 2017 | Dell Inspiron Mini 10 Notebook
It won't connect to the internet.It show full bars when you look at the wireless connection.
the bars only show your connection to an access point, like a router. Probably you should reset that device (router) and then try reconnecting... Or try connecting the computer up to the router with a cable and see if it works.
Sep 14, 2011 | Dell Inspiron Mini 10 Notebook
Hi, I have reinstalled my window XP SP3 but after reinstalling window my wireless(Adapter name: dell wirless 1395 WLAN mini-card) is not working properly. I have installed latest driver on my Dell...
Verify that you have the correct type of authentication in wireless- if your router is set to WPA2, then you would have to go under the connection properties > security tab to change it to match that setup. If that does not work, then the issue may be that the wireless card is defective and starting to fail.
Nov 22, 2010 | Dell Inspiron 1525 Notebook
Can't access internet wireles router says connected hp is a vista
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
Apr 23, 2010 | HP Pavilion dv6000z Notebook
How to connect to wifi in an hp notebook
First you need to check that the wireless button on the notebook is on or not.
Then you have to click on start - go to connect to - choose show all connections - there you will find the networks list - choose your network from the list and click connect at the bottom...if the network is secured it may ask you for pass key also.
If you have problems in connecting . check the wireless services is on or not .. to check that need to type services.msc in run box .. and in the services page check for wireless zero configuration double click it and the services should be started and automatic.
If there is not connection at all you can also check for drivers in device manager.. .under network adaptor- - check for drivers it could be broadcom wireless or intel pro wireless . uninstall them and reinstall it form recovery manager of your notebook ...
To access recovery manager you have to click all programs - then recovery manager - click advanced option in it - then driver download -
these are the steps you have to follow ..
Apr 13, 2010 | HP Mini 2140 Notebook
Dell Mini 10 problem connecting wirelessly
please update the wireless drivers fromo the support website that is www.support.dell.com and also update the latest version of bios, check for the setting with router , if still dosent connect,
Feb 12, 2010 | Acer Aspire One PC Notebook
Connection problems with linksys wrt120n and dell wireless wlan 1350 mini-pc card. was connecting fine for abt 3 weeks, then connections on both wireless computer was unstable. recycling the router worker...
Go to your Device Drivers and open the listing of devices. Select each line by line and hit UPDATE Drivers. If the drivers are current, it will just say so, if the drivers need to updated, the operating system will update to the new or current drivers for that device. Once that has been done, you should be connecting OK.
Feb 06, 2018 | Dell Inspiron 1150 Notebook
Wireless network problem with Dell Inspiron 600m.
Your wireless router is acting as the mechanism to hand out IP addresses using DHCP.
Sometimes glitches occur and I would recommend unplugging your wireless router from its power surce, letting it sit for a minute or two and replug it back in.
It will come back to life , reset itself and start handing out IP addresses to all computers and peripherals that normally connect to the router.
Nov 27, 2009 | Dell Inspiron 600M Notebook
ASUS PRO50G series laptop, wont connect to my wireless internet
pls tell me when u clik on connect wi fi what error come.
r u able to connect or not let me know please
Mar 23, 2009 | ASUS Eee 4G Notebook
Wireless connection
In order for me to deal with this query for you, could you tell me what brand and model it is the Laptop?
Fran10
Apr 10, 2008 | Dell Inspiron 6400 Notebook
Velocity Micro NoteMagix x30 Laptop Logo
138 people viewed this question
Top Velocity Computers & Internet Experts
Andrew Taylor
Andrew Taylor
Jovan Sakovic
Jovan Sakovic
Anthony Cardenas
Anthony Cardenas
Are you a Velocity Computer and Internet Expert? Answer questions, earn points and help others
