Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Can't send faxes , keeps saying document jamed
  • 203 Answers
Open the front cover by pulling it towards you (that is the cover where are the digits and other function keys), see if any paper has inside and than close the front cover and press the " Stop " button.
Remember if you do not close the front cover good the message will still appear on the screen because the machine thinks that the cover is not closed. That happen because of the sensor on the front cover which detects do the front cover is closed so check dose the door is good closed. If your machine do not pull the documents in the " document feeder " than open the front cover and you will see pair of rubbers inside, clean them with alcohol or glass cleaner and clean peace of cloth.
Posted on Jul 10, 2009
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
FAX will not send nor receive.
Free Fax Free Internet Faxing
You could try this if you have a normal computer scanner or the document is a file on your computer before being printed. Sounds like your fax machine is simply broken.
Feb 06, 2014 | HP LaserJet 3050 All-In-One Printer
Lexmark 5250 won't fax. I have installed everything several times but says something about OCR not working. It will scan & print instead of sending document to Fax. I can open Fax window, but...
Use the Lexmark All-In-One Center application to send faxes from your computer (make sure your computer is connected to a fax modem). From the Creative Tasks section of the All-In-One Main page, click Fax using PC modem. Follow the instructions on the computer screen.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
We have a canon i-sensys L 100 fax machine and it keeps coming up with the error Check scan Platform and we are unable to send faxes. How do we solve the problem.
Ok,Remove the papercover tray, if you look just above the paper tray you will see the scanner,close the scanner by pushing it upwards,and then your problem will be solved.
Mar 18, 2009 | Office Equipment & Supplies
Faxing
Hi:
You may have removed the paper but the reason why it is still saying paper jam can be caused by at least two things.
If you removed the paper, but it tore while you were taking it out then a small piece could be blocking a sensor or a sensor flag ( a spring loaded finger that the paper has to activate as it moves through the machine) It's possible that a small piece of paper could be blocking a sensor or you may have disloged one of these 'flags' in the area where you first removed the paper. Go back and look closely in that area for a piece of paper or a sticking ''flag'. Until you do that the fax keeps thinking that there is something in the paper path and will keep displaying that message.
Andrew
Jul 20, 2008 | Brother FAX-575 Plain Paper Thermal
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Xerox Fax Centre F12 keeps giving me error code E3 when I am trying to receive a fax from one particular client. I can receive faxes from others without problem, and this client says he can send faxes to...
Looking through all the service documentation and engeneering tips, and also searching the Xerox.com database, I find no E3 code for a F12.
Do you have the ECM mode on your mechine set to "ON" ?
That is the error correction mode.
I really can't find an E3 message in service documentation.
I will download a user guide and see if I can find it there.
Apr 14, 2008 | Office Equipment & Supplies
Cant't send out any faxes.
Are you using the little cord that came with the printer to hook up your fax. It is a special cord. You cannot just plug a phone line into the fax.
You have to use the little cord, or equivlent. Go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00014834&lc=en&cc=us&product=421991&dlc=en
Apr 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Mar 03, 2008 | Canon FAX-B160 Plain Paper Bubblejet
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
99 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
