Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Timing I have a ce-250 and just recently had the timing reset. I am having problems with it again. Can anyone explain to me how to set the timing ona ce250?
    Problem Solver:
  • 14 Answers
That needs a repairman because you have to reset the gears, if it is still having the same problem take it back to the repair center and they should fix it again for free because they did not solve the problem. I am sorry to tell you but those machines have been nothing but headaches to my customers, many have just bought new machines (our shop sells Brother and Babylock).
Posted on Jul 07, 2009
Pc light flashing on ce250 futura
Check that your USB is well connected at both end and that your PC is put on.
Oct 09, 2013 | Singer CE-100 Futura Computerized Sewing...
Unable to install ce250 software using windows 7
Looks like there is an update. Please get familiar for the website for futuras. http://www.futura-support.com/
Here's the link for your machine for the software update and instructions.
http://futura-support.com/products/ce-250/software
Nov 07, 2012 | Singer CE-200 Quantum Futura Computerized...
I cannot install the software on windows 7 for ce-250 i get an installation support file error access is denied. i cant get far enough to do the patch. what do i do now?
I've posted instructions that will help solve your problem for any machine, but especially for Singers. I've been using my CE250 for the last 4 months using the second method and my friend has successfully used the first for the past 9 months. Just follow the directions carefully and you should be fine.
Follow this link to the full instructions:
http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista
If you need any help, please leave me a comment back. I check back daily, so I'll be sure to get back to you within 24 hours. It's frustrating, I know. It drove me nuts until a guy who specializes in PC's and Windows helped me through a bunch of this!
May 31, 2011 | Singer CE250 Computerized Sewing Machine
Singer CE250 Futura problems with timing and bird nesting
Needle could be loose or bended or use another size. Put the needle all the way out and the insert a new one inside making sure is the right way in (flat part hasto be looking oposite of you).
another thing is that the Tension could be too tight.
Last, Rethread the machine with another thread to make sure is good.
Hope it helps
Feb 17, 2010 | Singer CE-200 Quantum Futura Computerized...
Future CE-250 software compatible with Windows 7?
I just bought a new Futura CE250 & had the same problem.
I fixed my "can not run an x86 build of this utility on x64 platform" by visiting the futura support website & downloading a service update. I have a computer with Windows 7 installed.
The website is www.futura-support.com
When you are there, click on the link on the left for "Service Updates."
The actual link to where I downloaded my udate is: http://www.futura-support.com/downloads/ce150.html
Happy Embroidering!!!
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Create my own designs
Your CE 250 allows you to do very basic digitizing by using Autopunch.
To activate autopunch, click on "create" from the top menu and select "autopunch" from the drop down menu. A new Autopunch wizard menu should open. Click on "next" on the browse to your jpeg file by clicking on "select". Keep on clicking on "next" until you get to the "customize stitch block" menu. Here you are able to remove unwanted blocks or change the stitching order by clicking on a block in the right hand menu and the clicking on the "Remove", "move up" or "move down" buttons.
By clicking on the radio buttons, just below the "move down" button, you can also select between Fill stitch or Satin stitch. When you are happy with your decisions, click on next and click on finish.
That is about all that you can do and autopunch will do the rest. I suggest you import a couple of dfferent clipart images and play around as discribed above to make you familiar with the program. You will also see different results by changing options.
If you are not happy with final results, I suggest you invest in a proper digitizing program, such as Creative Drawings. Visit the at www.drawstitch.com/Creative
Good Luck
Nov 19, 2008 | Singer CE-200 Quantum Futura Computerized...
I have a singer futura ce-250/ce-350 machine.
You need to do a tension test
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Oct 13, 2008 | Singer CE-100 Futura Computerized Sewing...
Copy of Software
I have the autopunch software. I may help you. (futura ce250)
Apr 24, 2008 | Singer CE-200 Quantum Futura Computerized...
Futura CE 200 Software Installation Media
Yes, from here: Driver Update Software for XP Vista 7 8 Install this software and make the update. Wish you best of luck.
Peter
Nov 02, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
319 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
