Question about Haier RRTG21PAA Refrigerator
I keep getting water in the refigerator. Everything works fine, but the water just drips and drips
    Brigadier General:
  • 8,619 Answers
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 03, 2009
    President:
  • 1,136 Answers
Hi, The defrost drain in the freezer is plugged. Remove the rear panel inside the freezer and see if the drain hole is plugged. Remove the ice and flush the drain with hot water.
I hope this helps you.
Vic
Have water dripping inside the fridge. everything else works fine. it drips from the top to the middle
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | GE Refrigerators
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Our machine keeps dripping water once load is finished. We have turned off water and checked hoses as well as the water inlet valve. Everything looks fine. It is only when the hot water is on, I shut...
I would replace the inlet valves. Even though the issue is only a drip now, the failing hot water inlet will drip enough water to overflow and flood your floor if left unattended. The failure code you see is because the washer senses the water connections. It is telling you that there's no hot water available. Replace the valve- soon.
Good luck.
Jan 18, 2011 | KitchenAid KHWS02R Front Load Washer
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser drip
Use a cup instead of a paper towel. Empty as needed.
Jul 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Water leaks from inside refrigerator
could be ice is forming at the vents already.
even though it is a frost less refrigerator, in some instances, you may want to defrost it manually or leave the door open for 1 day just to be sure that every ice in the fridge has melted. then plug it back in and observe it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Refrigerators
Water dripping inside fridge
OK, i see a lot of this, and on a fridge that is nearing 10 years old, its pretty normal. Now, we all know that water is leaking into the fridge section from up top because the drain is plugged that is under the evaporator.. now to fix the WHY it happened. most of the time this will happen because the fridge did not go into a DEFROST cycle for a while.. reason being one of two things... either the defrost timer has quit working, or the bimetal thermostat sensor that is clipped on the evaporator has failed. the bi-metal thermostat is usually located in the freezer behind the rear wall and looks like a round "clip on" with 2 wires coming off of it. one pic of one is here.
http://www.partselect.com/PartDetail.aspx?Inventory=371255&SourceCode=5&ModelNum=et18pk
instructions on how to test this is shown on the link.
(just replaced mine the other day, NO MORE WATER LEAKS! =) )
hope this helps!
Chris
Jun 15, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Haier RRTG21PAA  Refrigerator Logo
453 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
