1. Check the tension on the belt pulley.
2. Check the belt. If it is worn, replace it.
3. Check the felt around the front of drum (if applicable). Again, if too worn, replace it.
4. If there is a chirping sound too, check the drum's roller bearings (the look like little wheels. The may need to be replaced too.
Most of these fixes are relatively inexpensive, and parts can be found at your local appliance parts store. (Given the date of this posting, I hope someone else helped prior to me...)
When I use the sensor dry button, the dryer will beep twice and then stop within 5 minutes. If I use...
(More)
When I use the sensor dry button, the dryer will beep twice and then stop within 5 minutes. If I use the timer, it will run the allotted time and dries the wet clothes. How do I fix the sensor button?
model MDE5500AYW,beeping sounds when in use,coads reset. dryer not starting at all, lights on but...
(More)
model MDE5500AYW,beeping sounds when in use,coads reset. dryer not starting at all, lights on but not responding. unplug it for a day or so,plug it in it would start.bought a NEW control pad. put it in,plugged it in showed 50 and STILL did not work ??? Now what do i do?
Magtag Neptune MDE5500AYW electric dryer. Display and controls not working but light comes on...
(More)
Magtag Neptune MDE5500AYW electric dryer. Display and controls not working but light comes on inside dryer.
