I have had this problem several times. Almost every time all I have to do is remove the front panel and clean out the tube from the drum to the pump that pumps out the water. You can try gently squeezing it while the washer is on the cylce to pump out water. If that doesn't work you'll have to bail the water out and remove the hose to clean it out.
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has...
(More)
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has always worked great until this week. It seems to still be working, but there is a large wet spot in front of the unit which sits on carpet, so I know it is leaking somewhere, but the water bucket is still filling, and I can't see where the leak is coming from. Should we bother having it repaired or just purchase a new one. I am not sure what the life span on this item is. Has anyone had this issue?
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing...
(More)
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing this noise? What do I do to fix it? It's 4 years old.
has there been any recalls on this dehumidifier. if you press the shut off button and turn it off...
(More)
has there been any recalls on this dehumidifier. if you press the shut off button and turn it off you have to unplug it then turn the dehumidity level lower to get it to come back on
