Question about Jungle Nojo Babies Baby Crib Musical Mobile Safari
I can't figure out how to attach the musical part to the top piece and I have a round open white part that I'm not sure where it goes...The instructions in box appear not to be for same mobile
  • 903 Answers
The mobile clips to the side of the crib, and the long white shaft extends up and then out over the crib, ending in the hook. The music box (with the dial and on/off switch) clips onto the hook, and then the two perpendicular arms of the mobile itself meet and clip onto the lower hook on the music box.
Hope that helps!
Posted on Oct 24, 2010
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
I inherited two different blowers. i can't see how the only bag i have can fit on my weed eater barracuda 2595 and can't find any diagrams on line. once i open the spring door the bag doesn't really fit...
OK this may seem difficult but its really not. The spring door there are only 2 things to do with it open. Either you put in the round circular attachment and then close the door or you attach the bigger of the 2 "funnels."
The big funnel is used to **** up the leaves and it will NOT work WITH that circular attachment attached. The Barracuda will NOT blow leaves without the circular attachment.
If you want to blow leaves, open the swing door, put in the circular piece with a twist to keep it in place, close the door and attach the smaller "funnel" to the smaller opening on the front side of the blower.
If you want to **** up leaves open that swing door, take out the circular piece HOLDING OPEN the swing door and in that same place attach the larger "funnel". Where the smaller funnel goes is where you attach the bag! There should be a small opening in the bag with a velcro strap. Put that over the opening of the blower, attach in place with the velcro and your ready to **** the leaves! When putting on the bag, make sure the bag shoulder strap is facing the top of the blower, not the swing door.
Hope that helps. Now on to find the solution to my problem!
dlandlrd
Oct 30, 2010 | RTO Weed Eater Electric Barracuda 2595...
SHE6AF06UC/03 upper wash arm came off. Have arm (d'uh) and round piece that goes thru it. Seems to be another piece that connects arm assembly to top of unit as that round piece can't snap into what is...
Welcome to FixYa.
If you follow this link below and save the file and then open it,( pdf about 5mb in size ) refer to page 21 it will illustrate how the upper arm is attached.
http://cid-674627ce75316bb3.office.live.com/self.aspx/Bosch%20Stuff/DWcompleteguide.pdf
Let me know if that works for you. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Oct 30, 2010 | Bosch Dishwashers
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
I get a 1200 error when trying to fax
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
My Tappan electric drier make a loud screeching sound like an axle with no grease. I can't figure out how to get the front panel off to locate the source. Model MDE336RES1
These are known for this. You will need to replace the rear drum bearing. Go to http://www.partselect.com/PartDetail.aspx?Inventory=459829&SourceCode=1 this is the part you will need. ($22.32 + shipping) It's located at the back of the drum. The round silver piece goes on the drum and the white plastic piece goes on the back panel of the dryer. (Notice the round silver ball. Make sure to not loose or forget to put it in when repairing) You get into this machine by going through the top and front. Not the rear. Good luck
Nov 16, 2009 | Dryers
When I took the base cover off the vacuum to clean the roller, a metal piece that is bent in half, as well as a white plastic stick piece came flying out. I think it might have to do with holding the...
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Aug 09, 2009 | Eureka 411A Upright Vacuum
Skybox parts # 4387535 installation issues
You don't need to keep the round metal piece or the black wire that you take. The replacement part (flat one) is installed in its place. Put it in first, attach the green wire to it, and then put the two prong piece and install the wires (blue, white and brown) as you took them off the original part.
Apr 17, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
I have a hoover windtunnel bagless that the filter fell out of on accident when I was trying to dump it and I can't figure out how to put it back in
Hi, You don't say which model windtunnel you have but most are the same. The canister is in two sections with a Hoover emblem to the right of the handle. this is the side the filter goes on. The bracket slides out and holds the round filter, the round filter snaps into the bracket so that the end of the filter with the opening goes down to fit the hole in the bottom of the canister. When putting the canister back in the vacuum be sure the top goes back flat on the canister and the locking lever is open all the way. You have to slide the canister back in level and then it will drop down into position you can't tilt it. now you can lock it. Good Luck!
Jan 29, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Nov 14, 2008 | Eureka 411A Upright Vacuum
Jungle Nojo  Babies Baby Crib Musical Mobile Safari Logo
265 people viewed this question
Top Jungle Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Jungle Toy Expert? Answer questions, earn points and help others
