Question about Maytag Washing Machines
Maytag Performa will not drain
My wife was washing clothes and got to the last load, towels. The washer filled and went through the cycles to rinse where the water did not drain and the washer just stopped.
I tried other functions and they work up to the rinse cycle.
  • 2,418 Answers
If this is a direct drive washer (no belts) you have a bad water pump or a sock has gotten sucked in to stop it up. get under it look for two hoses going to a white looking valve. If you pull the hoses look out for all the water to flood out so be preped. Pull the pump out and ck for sock or fuzz in it then try to turn to trun by hand if its hard its bad. repost if need more help.
Posted on Jul 03, 2009
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Recently our Maytag Performa washer has started
The transmission might be going bad.
Nov 02, 2009 | Washing Machines
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
May 28, 2008 | Maytag Performa PAV2200
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Series of clicks..then dead
The load size adjustment only changes the level of water used, this could not cause a fault,sounds like a faulty rinse valve or depending on model a faulty or blocked pump. Regards Engineer
Feb 27, 2007 | Maytag Performa PAV2200
Washing Machines Logo
76 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
