Question about Creative Labs ZEN Vision:M Digital Media Player
My computer and zen not mixing!
I have been charging and syncing my zen vision:m on my laptop for almost 6 months. My computer was reading it fine. all of the sudden, it will no longer charge or sync onto my computer. but it will charge on any other computer than mine. In "My Computer" it shows the zen is connected, but none of my software, not even windows media player, will read it! helppppp!!! I want to add new music and be able to charge it :(
Re: my computer and zen not mixing!
I'm having the same thing with my creative zen vision w the only thing it won't charge on laptop i moved it to desktop and to my surprise it worked there i was so mad when it didn't work on my laptop i like to lay on the bed and use the laptop (lazy what can say ) lol. it would sync the music fine on my laptop but doesn't charge very well. at least i know i'm not the only one
Posted on Feb 14, 2008
  • 4,402 Answers
First try different usb port
then different computer if you have one
make sure you have media player 11
remove the usb drivers and reboot and let the computer reinstall them
Posted on Dec 12, 2007
0 characters
3 Points
Charging problems
Your player's internal battery hs died. You will need to obtain a replacement. Check your user manual for size & type, or check it out on the web. Sellers from China offer large range of replacements.
Apr 13, 2010 | Creative Labs ZEN Vision:M Digital Media...
Computer won't recognize zen when it's connected
please tell the model it could help solving the problems.
for us to download the specific drivers of the model.
May 22, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen won't turn on
had same prob to the T...found this post and it fixed's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen vision:M will not connect
You'll need to install the Creative Labs software. Put the CD in your computer and install it.
Jul 04, 2008 | Creative Labs ZEN Vision:M Digital Media...
Vision M not recognized
I'm having the exact same problem. My zen is 'charging' but isn't detected anywhere on my pc and I'd leave it charging for days but nothing happens. I've tried different usb ports, reinstalling the software several times but nothing. I recently reinstalled Windows and with my new pc my Zen cannot work on it for some reason?! I put previous files from my old pc onto my Zen hoping that I could transfer them onto my new Windows pc but I fear I've lost the data on my Zen completely. Arggh, any suggestions guys? Please..x
Feb 29, 2008 | Creative Labs Zen Touch MP3 Player
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
if you are using a fromt usb port- switch to the back usb. The front ports don't always give the zen enough power. Also- look in Device Manager and see if there is a zen listed there- and if it is does it have a yellow exclamation mark? It may not be the zen that is having problems but your computer.
Oct 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen vision M wont dock
Oct 08, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
238 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
