Question about Dryers
Kenmore dryer stopped running
Our Kenmore electric dryer model 110.96590100 has stopped running; when switch is turned on, a loud unusual noise is heard; When Sears technician was call and he heard the noise, he said motor has gone out; he did not check anything inside the dryer just based on the noise when switch turned on; is that noise enough to indicate motor is bad? I realize the dryer is old and its use has to run out sometime.
  • 1 more comment
  • 1philcollins Jul 03, 2009
    Thank you for your reply. The noise is a constant hum.
    I can't see the belt-tried to lift the front up but not sucessful. We already paid Sears $65. I called Sears about my concerns and they are going to send another technician to check the dryer at no cost to me. I will have your comments handy for talking points.
    Thanks again for your help.
    Okay-thanks. I'll do this probably tomorrow and let you know if I have more questions. This has really been helpful.
    President:
  • 1,136 Answers
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Posted on Jul 03, 2009
  • 2 more comments
  • Victor
    Victor Jul 03, 2009
    You are welcome, I have to ask questions so I can help. Does the hum last only when the start button is being pushed? Does the drum try and turn? If the belt breaks, the motor will hum while running. I just want you to be sure of what is going on so you will know how or if this should be fixed.
    Vic
  • Victor
    Victor Jul 03, 2009
    Vic
  • Victor
    Victor Jul 03, 2009
    I am sorry, I should have sent you these instructions.
    UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
    There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
    I hope this helps you. If I can assist you further, please let me know.
  • Victor
    Victor Jul 03, 2009
    Ok good luck
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
I have a Kenmore Elite Dryer Model 110.66992500 that will not start. When the start button is pushed, it only makes a click. During the last use, the dryer was working fine then all of a sudden while...
heatman101
Apr 01, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
