PC won't go all the way on.
When I press the button to start up, the light goes on in the button, and the hard drive light is on steady, but the monitor stays black.
    Problem Solver:
  • 16 Answers
Make sure the monitor is properly plugged in. Make sure that if you have more than one video signal on your computer, that you have it plugged in to the right one. (A video card overrides normally an on-board video connector). Make sure your monitor has power and has a power light on. Does your PC beep as it comes on? If so, it is indicating a very basic problem with the machine.
Requires more input to fully resolve.
Posted on Jul 03, 2009
Msi vr600x won't start.
Remove power unit, battery, RAM and hard drive. Press the power button to discharge any energy that is left.
Insert the power plug and press power. If the laptop goes to the start screen, the motherboard is probably OK. remove the power supply. Add the RAM and repeat. Then do it again adding the hard drive.
There will be a point when the faulty item is identified or it will now boot.
Nov 11, 2013 | MSI MegaBook Computers & Internet
Seagate backup plus srdospo
Either your driver for the hard drive has messed up or you need to exchange it for a new hard drive.
Usually just exchanging it causes less headaches and frustration than trying to fix it manually. It could also be that something is physically wrong with the drive, such as the arm inside the hard drive.
Good luck and hopefully that helps!
Jul 06, 2013 | Computers & Internet
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
Computer won't come on. light is blinking in back of hard drive.
Try unplugging from wall socket then press on button (this clears out extra electricity in PC). Plug back in then try to turn on again. If PC is older, try blowing out the dust inside tower especially around the CPU fan.
Aug 04, 2012 | Compaq Computers & Internet
My 1501 Dell Inspiron turns on but I have a blank black screen. The only light that shows is the power light on the upper right side of the laptop.
Power getting to the laptop. Try first to see if this will give a screen image on an external monitor, listen for the sound of the cpu fan, hard drive and DVD rom drives clicking, see if the DVD rom drive will open if pressed.
Then remove battery and AC adaptor, press the power button for 30 secs, refit mains only and try this on mains supply (no battery)
If this fails to boot, check the light on the ac adaptor is a steady green, flashing green indicates power is not fully reaching the laptop (motherboard problems)
If it is steady and the LED power light on the laptop is steady, suspect the DC jack socket. If this feels loose or sloppy, it will need replacing, depending on the type fitted, it may be soldered onto the board, or a wired connector, which sometimes goes bad.
After that, I'd suggest that a capacitor has gone on the actual motherboard and you will need to strip the laptop to check it.
Jul 18, 2011 | Dell Inspiron 1501 Notebook
I have a Dell Dimension 4700, the problem is that recently, i went to start it up, nothing would happen, the 4 ABCD lights don't light up, and i notice this steady amber light. So it was determined that a...
You can try to reseat the CPU (processor) chip. Inorder to do that you have to remove the heatsink and then reapply thermal paste (compound) to the surface of processor. The processor rarely goes bad.
Apr 09, 2011 | Dell Dimension 4700 PC Desktop
The machine won't power up. The green light on the PS flashes. What does this mean? If I disconnect the large plug from the mother board the green light will come on steady. Plugging it into the mother...
Can you tell if the flashing is a pattern. count the flashes ( long and short) in a cycle. This will provide an error code to hopefully discover the problem.
You may also try removing and reseating the RAM and Video card, blowing out the connectors with compressed air before reseating.. Also look closely at the components on MB for any signs of swelling, leaking, burning etc. I suspect the MB.
Nov 11, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
