I have a Dell 924 printer and the language is set on ''some'' kind of other language. How do I reset it to English?
    President:
  • 1,901 Answers
Resetting the Language on Your Printer
If you need to change the default language used on the operator panel, complete the following
steps:
1) Press the Power button to turn off the printer.
2) Press the Power button and the up arrow button simultaneously.
3) When the language settings appear, press the Arrow buttons to scroll to your
language.
4) Press the Menu button to select your language.
Thanks for using Fixya.
PS. For reference, here is a link to your User Manual:
Dell 924 Manual
Posted on Jul 03, 2009
How do I change the language from German to English on my printer?
from support.dell.com:
Reset the Language Back to Factory Defaults
  1. Turn off the printer.
  2. Hold down both the Right Arrow button v305_right_arrow.jpg and the Start printer_start.jpg button.
  3. With both buttons held down, turn on the printer.
    new_note.jpgNote: This will reset the printer language to the default which is English. You will have to re-select your specific language and country and also enter the date, time, and fax information.
May 13, 2012 | Dell V305w Printer All In One
Hi! i m to use urdu language in ocr software so that i can edit my english and urdu text in text form in Msword. thanks. hope u will answer soon.
Click start, all programs, Abbyy Fine Reader. Click on Language and select the language you want the OCR Program to use.
Rick
Jan 31, 2011 | Dell 924 All-in-One InkJet Printer
How do you reset the language to English on the Dell 924 all in one
I dont know how you can change the language apart from downloading the software in english, this is available from Dell / support and find your model
Aug 20, 2010 | Dell 924 All-in-One InkJet Printer
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
How do you change the language
To set the language on your printer initially:
1. When you first power on your printer, press the Arrow buttons to find your. language. 2 .Press the Menu button to select your language.
Resetting the Language on Your Printer:
If you need to change the default language used on the operator panel, complete the following steps:
1 Press the Power button to turn off the printer.
2 Press the Power button and the up arrow button simultaneously.
3 When the language settings appear, press the Arrow buttons to scroll to your language.
4 Press the Menu button to select your language.
Sep 28, 2009 | Dell 924 All-in-One InkJet Printer
How do I change the language to English on the printer
Power off the printer.
Press the up button and power simutaneously.
When the language settings appear, use the up/down arrow to find your language.
Then press menu to save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Dell 924 All-in-One InkJet Printer
I just purchased a Dell printer with complete Monotor and computer. All in 1. I am unable to get the printer set on English. I have tried using the arrow buttons and English Language will not come up on...
Hi Tatum,
Not to worry - this is easily fixed. Normally, when you turn on the printer for the first time, you can set the language immediately by using the up and down arrow buttons to select English. If for some reason it didn't get set correctly the first time, here's the way to reset it:
1) Turn off the printer.
2) When it's off, press and hold the POWER button and the UP ARROW button at the same time.
3) When the printer turns on, the language settings will appear again. Use the up and down arrows to choose English, and press MENU to select it.
For your reference, the 924 user manual can be viewed at the following web address:
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Dell 924 All-in-One InkJet Printer
Ever sence I have received my Model926 Printer service tag # 692tsd1 serv.code 13609638613 I have had trouble with the display not giving me the English language. I talked to the service department by...
Kindly try the following steps to solve your problem , with the language setting on the printer. If the same did not fix the issue , get the printer replaced from Dell, because if the solution below did fix your issue there nothing much that can be done.
Restore the Dell™All-In-One 926 printer to factory default settings.
To restore the Dell™All-In-One 926 printer to factory default settings, follow these steps:
new_note.jpg Note: Restoring the printer to factory default settings will erase any data added into printer memory, such as fax phone numbers.
  1. Turn off the printer power.
  2. Disconnect the printer power brick and wait for 10 seconds.
  3. While holding down the Start and Cancel buttons, re-insert the printer power brick.
  4. Hold the Start and Cancel buttons until the power LED begins blinking and the printer shuts itself off.
  5. Turn on the printer power
Thanks
proton
Jul 25, 2008 | Office Equipment & Supplies
Changing language dell 922 printer
To change the language on the Dell 922's display, turn on the printer, then press and hold the Power and Cancel buttons at the same time for about 10 seconds. The language choices will then scroll across the LCD press the up or down arrow key till english appears, then click Menu.
Sep 15, 2007 | Dell 922 All-In-One InkJet Printer
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
