Question about ASUS F3Jc-AP141C Notebook
I have a dell 1545 and when it is plugged in the battery icon says "plugged in battery not charging" when i unplug the ac adaptor and plug it back in it says "the ac power adaptor type cannot be determined" even though it is the one that came with the laptop and worked fine yesterday
  • 197 Answers
Try to remove the battery first and plug in the ac power adaptor and see if it works. if yes, then your battery is faulty.
if it doesn't work i suspected that there's a problem with the power socket from your machine. you can check it with the nearest service center near you.
Posted on Jul 03, 2009
  • iya velasco
    iya velasco Jul 03, 2009
    try to remove the battery first and plug in the ac power adaptor and see if it works. if yes, then your battery is faulty.
    New Friend:
    Problem Solver:
  • 6 Answers
There is only one reason, your charger doesn't match with the specific watts required by your laptop. To avoid damage to your laptop, you have to change your charger with specific watts charger ASAP.
Posted on Oct 11, 2014
2 Suggested Answers
myrlex
  • 674 Answers
SOURCE: i have a dell 1545 and when it is plugged in the
change the charger that is not the same watage. if the writen is the same has defect the charger try another charger to avoid broken you pc
Posted on Jun 11, 2009
Ac adapter problem with dell inspiron 1545
TRy to remove the battery, then power the laptop on with only the ac power adapter inserted. if it powers, then your adapter is ok, and insert battery while its on, battery charging should start. otherwise, you could be having a problem with your charging system.
Regards
Apr 19, 2010 | Dell Inspiron 1545 Notebook
Dell latitude 810 will not power up and says low battery
if you plug in to charge your battery and its not charging replace the battery with a new one and a ac adaptor plug, just to avoid any more damage to your pc notebook, dont try to repair if you are unsure on what to do
Nov 23, 2009 | Dell Latitude D810 PC Notebook
Dell 1545 plugged in with correct adapter, but not charging.
Battery packs die after a while they are unable to hold charge this sounds like your case, you will need to replace battery pack, if you get two good years out of such you have already done well.
Nov 07, 2009 | Dell Computers & Internet
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell inspiron b130 power problem
try running with battery out it should still work as long as it is pluged to a/c
Feb 18, 2009 | Dell Inspiron B130 Notebook
Pc is telling me to plug it in when the battery is at 90%
The battery needs to be conditioned. To condition a battery, plug in the AC adaptor and charge it to 100%. Unplug the AC adaptor and run the battery completely down to 0% or until the computer shuts itself down or goes into a hibernate mode. Once this occurs, plug the AC adaptor back in and fully re-charge the battery to 100% again. You should now be good to go.
Let me know what happens and if this has solved your problem. Thank you, Binary Bob
Dec 07, 2008 | Acer Aspire 3680 Laptop
Battery charging status remains constant (not increasing)
I've have seen a number of different batteries do this, and I recommend what is called 're-conditioning the batteries. Do this by running the battery completely down to 0%. Then do a complete re-charge of the battery to 100% (if possible). If it charges to 100%, run it completely to 0% again and then recharge it. If it does not charge to 100%, then you may have a faulty or old battery which will need to be replaced. The AC adaptor and battery have circuitry in them and might be retaining incorrect info in them. They can be reset by unplugging them for a few minutes and then plugging them back in. There might be a specific sequence of what to unplug and when, in order to reset this circuitry. Try a couple of them. (ie. Battery, AC adaptor in to battery, AC adaptor into the wall, etc.)
Let me know what happens. Binary Bob
Nov 10, 2008 | Dell Inspiron 6000 Notebook
T30 2366 8GA After removing AC Adaptor battery icon shows Charging and working on AC
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
May 13, 2008 | IBM ThinkPad T30 2366 Notebook
ASUS F3Jc-AP141C Notebook Logo
418 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
