Question about Toshiba TDP-T45U DLP Projector
Faulty projector I switched my projector on and it made one beep, it then shortly after made two more beeps and would not light up with an image. Any ideas on whats wrong??
Re: Faulty projector
Our projector is a Toshiba TDP-T45U Mobile forgot to mention this in my post
Posted on May 30, 2008
  • 563 Answers
You will have to give a Make and Model of your Projector.
Could either be your lamp that needs replacement or a faulty Ballast ( lamp's powersupply )
Posted on Apr 01, 2008
0 characters
3 Points
Acer projector blue light blinks and fan blows and no picture
As far as I can tell this looks like a lamp problem. Unless some of the fans are not able to cycle up tehn it would shut down before it overheats
Feb 14, 2014 | Acer H5360 3D Video Projector 3D
Projector keeps beeping. How do I make it stop?
The beeping is an error, you need to get the projector serviced.
Mar 12, 2012 | Sanyo PLC-WXU30 Projector
My NEC VT660K wont power up.
Some suggestions from NEC support:
Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on.
• Ensure that the lamp cover or lamp housing is installed correctly.
• Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you’re presenting is particularly warm, move the projector to a cooler location.
Hope this helps.
Nov 05, 2009 | NEC VT660K Multimedia Projector
My nec vt48 projector gets hot and turns off. It gives off 3 beeps a few seconds after
This problem and the error beep codes indicate a lamp that needs to be replaced. The correct part number for the lamp is VT85LP. Basically the lamps are rated with a life expectancy of 2000 hours. At the 2001 lamp hour (3001 in eco-mode) the LCD projector will power on, but not display an image, due to the indicator requesting the lamp be replaced and the lamp hours reset (hold the help button on the remote for 10 seconds when powering it on).
Aug 19, 2009 | NEC Multimedia Projectors
Faulty projector
Before a modern projector will strike the lamp it will check if the lamp is good either by remembering how many hours the lamp has been used or by measuring it with its own internal circuitry. if the test fails it will not strike the lamp because starting a bad lamp can potentially damage the projector and surrounding property.  Is the lamp old? Does it need to be replaced? if not then it may be a logic board and now requires service from a trained repair technician that has access to the parts it may need.
May 17, 2008 | Dell 2100MP Multimedia Projector
Lcd projector beeps every minute
Hi Jenrowe
Try resetting the lamp and filter timer , if this still occurs reset the whole mashine.
Apr 24, 2008 | Hitachi CP-X275 Multimedia Projector
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Multimedia Projectors
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Toshiba TDP-T45U DLP Projector Logo
243 people viewed this question
Top Toshiba Multimedia Projectors Experts
Electro Med Services...
Are you a Toshiba Multimedia Projector Expert? Answer questions, earn points and help others
