Question about Brother MFC-7820N All-In-One Laser Printer
Is there a way to feed photos through the feeder without getting stuck for the Brother 780N? Adapter, different direction, etc.
    President:
  • 2,306 Answers
There's no good way to feed photos on the Brother. It's designed for plain bond paper and doesn't do well on photos at all.
Posted on Jul 03, 2009
Uneven feed
machines can have single or double feeders. what type does yours have? feeding problems can usually be fixed by a good cleaning+ oiling of the feeder mechanism which regularly gets clogged with lint+threads/scrap threads. brush it out thoroughly with a stiff-bristled brush like an acid brush. apply 1 drop of oil to each feeder seen on the foot-plate. wipe excess oil off with a clean dry rag being sure not to get any debris from the rag caught in the feeder(s). other problem might be your bobbin tension. this is usually adjusted on the bobbin race with a very small screwdriver.
Feb 22, 2014 | Brother PC-420
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
Not sure how to feed the envlope into the printer
Follow these steps to use the photo/envelope feeder for single envelopes:
1. Insert the envelope into the photo/envelope feeder with the side to be printed on
facing down and the flap to the left.
Push the envelope into the printer as far as it will go without bending.
3. Slide the photo/envelope feeder forward as far as it will go.
Thank you for using Fixya
Oct 08, 2009 | HP DeskJet 6988 Printer
When paper is going into the paper feeder it is is getting wrinkled immediately and jamming the feeder
Sounds like someone got something stuck in the ADF (Auto Document feeder). See if it looks like the paper is really getting wrinkled up more on one end than the other and focus on that side of the feeder. I have seen post it notes cause this problem. People put in their originals and forget to remove post it notes before feeding the documents through. They come off and get stuck in the feeder. Without more detail it is hard to say what is stuck in there but it sounds like there is something impeeding the paper path. Shine a flashlight in there to see.
Oct 03, 2009 | Minolta Di3010 Copier
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
I865 flashing 3 times
That's a "paper jam" error that can be fixed by removing all paper and pressing the resume/cancel button. Then replace the paper in the feed chute.
The printer can straighten out a crooked feed to a very limited degree. The photo feeder attachment can interfere with a really full 8x11 feed. The i860 is very susceptible to overfilling the 8 1/2 x11 feeder without notice until you try to print. I usually remove the photo feeder until I need to print photos, and keep the regular paper feeder no more than 3/4 full. I pull out the regular paper when printing photos.
Feb 24, 2009 | Canon i860 InkJet Photo Printer
Feeding photos into scanner
try different position and push down into feeder.
Feb 09, 2009 | HP LaserJet 3050 All-In-One Printer
I have a Brother MFC 8220 Super G3. It will accept incoming faxes without a problem, however when I try to fax anything out at all it jams and says to call BROTHER
most likeli there is something stuck in the feeder. cut a file folder to 8x11 and force feed it thru the feeder manualy if there is any paper un there it will be pushed out, good luck brother tech
Jan 06, 2009 | Brother MFC-8220 Fax
Brother MFC 8440 Scanner has a line
Whoaaaaaaaaaaa!!!!!!!!!!!!!!!!!!!!!!!!!! No need to da all that. Lift up the Doc feeder and look at the SMALL strip of glass, you will see a dot or something on it, clean w/alcohol. Voila taken care of. the dot ( pen mark, white out, etc...) makes a line because the document is Moving and that dot now looks like a line to the copier. :)
Sep 26, 2008 | Office Equipment & Supplies
Epson stylus photo r340 paper feeder
the friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Jan 29, 2007 | Epson Stylus Photo R340 InkJet Printer
Brother MFC-7820N All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
