Question about GE Dryers
RCKH315EHWW model Moffat stackable 240 v dryer.
RCKH315EHWW model GE/Mabe/ Moffat stackable 240 v dryer. Made in Slovenia.
This machine takes over one hour to barely dry 4 tshirts. Is this normal?
  • Chris Goulet Dec 19, 2010
    Yes this is normal for this dryer. It is a very low power model.
    See: http://www.homedepot.ca/webapp/wcs/store...
    Sorry the URL was too long and got trucated. Got tohttp://www.homedepot.ca and search for RCKH315EHWW
localwonder
  • 6784 Answers
SOURCE: GE Harmony electric dryer model DPGT750EC1PL- very
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jun 06, 2009
carlsbiz
  • 1124 Answers
SOURCE: Dryer takes a very long time to dry a load.
Some dryers have more than one heating elliment..
A way to check is -- take the exaust hose off.. Put a mirror so you can see into the hole & hopefully see the heating elliment(s).. When running they should glow like a stove burner..
If it is not gloing its not working & needs to be replaced..
I suspect that one may have went out..
I hope this helps !!
Please rate me good ;o)
Posted on Jul 12, 2009
  • 14 Answers
SOURCE: My dryer seems to be hot, however it takes forever
Your heater coil has burned into 2 parts. Find a friend WHO IS KNOWLEGABLE about dryers, Call a repair man or find a good used dryer. I understand this isn't what you wanted to hear, but this involves lint and 220 voltage. NOT to be taken lightly. The coil will cost around $50 and the repair men will be a minium of $75; Look in the paper and buy another one....
Posted on Aug 25, 2009
  • 2468 Answers
SOURCE: GE stackable dryer not heating but it is running.
check the hi-limit and cycling switches on the element case along with the element itself for continuity,then if these are o.k. then check the thermal fuse on the vent pipe conduit inside the dryer near the vent connection as this is in line with the element and this opens up the element cant heat
Posted on Mar 27, 2010
  • 41 Answers
SOURCE: I need to replace the front seal on the drum of my
The drum gasket is WE9M26. To install it, it is the biggest job compared to any dryer gasket of hundreds of dryers that I have worked on.
See RCKH315EH0WW at:
http://partsnet.geappliances.ca
In summary:
-Remove top
-Remove console (some plugs require a tiny screwdriver to pry off. Do not pull on the plugs too hard.)
-Unscrew front panel (some screws are on the front of the bottom panel. Do not remove yet)
-Remove both side panels (cut off zip ties)
-Remove front panel
-Remove air director (big white plastic part)
-Do NOT remove drum. The belt is too difficult to reinstall.
-Apply contact cement in the groove in the air director. Install new gasket.
-When reassembling, line up the duct with the rectangular groove in the air director.
Good luck and congrats if you succeed!
Posted on Jun 10, 2011
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
What can cause an electric GE dryer to not start? Model number DCVH680EJ1WW. cogtinuity with motor switch, door switch, high limit fuse, thermistor & no cogn. with the thermodisc or heating element.
As a repair technician, just came across this crazy situation with GE / Hot Point / Moffat machines several times. It is all made by GE corporation.
The Dryer is not starting because your cycle selector knob is broken inside and it is just turning without turning the timer selector.
GE corporation machines are good. But those damn chinese plastic knobs break from inside. I have driven 50 km to find out the knob is broken. I had to charge the poor customer.
Apr 15, 2015 | GE Dryers
Frigidaire fex831fs2 stackable dryer takes too long to dry and leaves clothes damp
Good Afternoon Famties4,
I understand that the dryer portion of your laundry center, model#FEX831FS2, takes too long to dry, even after making sure the vents are clear. First, I suggest checking the exhaust duct, making sure it is at least 4 inches in diameter and made of rigid or flexible metal. Secondly, make sure the duct has no more than two 90 degree bends and must not exceed length listed in the INSTALLATION INSTRUCTIONS. Lastly, make sure your dryer is connected to a 240 volt circuit. Drying time will be 20% longer than drying on a 240 volt circuit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 17, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
Locate model number on a GE stackable
look on the front of both items if not look for a label it may be in the door area or on the rear
Aug 25, 2012 | GE Washing Machines
Install dryer belt any tricks to make it simple on a GE WSM2700W/WW/AA Top Load Stacked Washer / Dryer
Nothing on a stackable is easy to replace and no tricks so just take your time and you'll get it on.
Sep 27, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
I just moved into an apartment equipped with a stackable moffat MCCH6110HSS washer and moffat 350A4502P547 dryer. I've discovered that the washer appears to repeat the rinse/spin cycle over and over again...
HI, I spent many years in apartment maintenance and most communities have maintenace staff to fix issues you have with their equipment,call the leasing office.The most likely cause is a bad timer.
Mar 06, 2011 | Washing Machines
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
I need to replace the front seal on the drum of my Moffat dryer (model # RCKH315EHWW, and am wondering if that is something that I would be able to do myself? Or, how much can I expect in labour? I already...
In summary:
-Remove top
-Remove front panel
Jan 20, 2010 | GE Dryers
BOUGHT A USED STACKABLE FRIDGIDAIRE AND NEED THE PLUG FOR IT, WHERE CAN I GET IT? WHERES THE MODEL NUMBER ITS A HEAVY DUTY CROWN SERIES
The Model number could be on the top of the machine or around the dryer door or by the washer lid. if your looking for a 220/240 volt 3 prong cord you should be able to get one at lows or home depot
Jan 09, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryers Logo
420 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
