Question about Linksys WAG200G Router
I can't open a port to show to my web site. This works only localy.
    President:
  • 623 Answers
Look at this page from Linksys.
You can see that you want to go to "Application and Gaming", then to "Single Port Forwarding".
You want to setup your router like the first line:
HTTP [you can put here whatever you want] | External Port 80 | Internal Port 80 | Protocol TCP | IP Address [your web server's IP address] | Enabled [tick yes]
In the second line you write exactly the same except you replace Protocol "TCP" with "UDP".
Don't forget to enable both and to save the settings!
You should give your web server a static IP address (not via DHCP!), to ensure it is always the same.
If you have any more questions or something is not clear to you, just come back here and leave a comment - I'm happy to help.
Posted on Jul 14, 2009
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
Do compaq presario m2000 laptops have sata ports
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Jan 05, 2013 | Compaq Presario M2000 Notebook
I am unable to browse iternet, it showing massage that cannot connect for an unknown reasons please check your internet setting and change them if needed . currently i am using htc touch diamond (cdma)
There could be many reasons for your problem.
1. If you use proxy server, make sure the server and the service are up and running
2. If you use proxy server check the Internet options and look for the correct values in the required fields.
3. If you use wireless router check the connection to the router.
4. If you use router check the network configurations. Many of the routers have internet connection test. So login localy to the router interface and check the connection.
5. If everything above is correct try pinging a website from cmd. Open command prompt Start->Run->cmd. Write the command "ping www.google.com" (without the quotes). If you have ping look for application that blocks the http traffic on port 80. If the result is "Request timed out" try to ping 209.85.148.104. If you cannot ping any site or computer outside your network, then you have to call your provider.
Mar 01, 2011 | Computers & Internet
My hard drive will not show up on my laptop when I plug it into the USB port. My USB ports work fine on the laptop because other devices show up. My hard drive was working before, but now it won't show up...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 11, 2010 | Western Digital My Book Essential 1TB...
Had a different router everything was working fine, until i replaced my router to a dlink dsl 2640u , wireless router. i can open all sites but sites beginning with https cant be opened. it says web page...
I suspect that you have port forwarding rule (virtual server) on port 443 (https) on your router. Try to remove rule or just reset router to factory settings. I have the same router and this problem did not happen. You can also install Router Commander program to boost up router performance.
Aug 29, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to work the built in camera
For conferencing, the newer instant messaging software - yahoo, msn, aol, have video capabilities. To capture localy look for video capture software or check cameras and scanners in control panel. Or type "web cam" in help and support from start menu.
Nov 21, 2009 | Dell Inspiron 530 Desktop Computer
My printer hp officejet 5600 dose'nt want to install with,or without the disk.the computer reads that it does not have the requirments.so i figure its not compatable with vista.So what can i do?
>well you can use generic driver which has minimum requirements but this will allow you to print but not scan
>go to control panel
>go to printers
>open printer folder then click on add a printer
>select localy printer and select usb as local port
>select hp as manufacturer and select deskjet 990c as driver
>this is a generic driver which will work on mosy hp printer
>just rename the printer icon on the printer folder to the correct printer name that you have
Sep 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Network card
Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
Nov 12, 2008 | IBM ThinkPad A21m 2628 Notebook
Asp
Hi, Have you checked your security permissions on the 2003 IIS ?
Are the users using it as Intranet or Internet?
Is the site internal/external or possibly firewalled with rules restricting correct port operation and access permissions?
x-b-m
Feb 19, 2008 | Microsoft Windows Server Standard 2003 for...
Web Server Crashes on port 80.
A couple of questions for you...
1) What do you mean by 'crash'? How do you know its crashed?
2) Can you look in the Windows Event Viewer to see if there are any warning/error messages in the Application or System logs around the time of the starting or crashing of your web site on port 80? If so, anything that suggests the issue. If you don't understand the errors, try posting some of them here.
3) Is there any other web server running on port 80? If your running Internet Information Server, open the Internet Information Server Manager (mmc) console and click on "Web Sites" and it should list all the sites in the right pane. If you have anything 'running' on port 80, it will conflict.
4) Are you running Apache or any other web server on the system? If so, you're going to need to look at those configurations as well.
5) How about any other applications that might have a built in web server?
Let me know.
Jan 14, 2008 | Computers & Internet
Linksys WAG200G Router  Logo
169 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
