Question about JVC MX-KB30 CD Shelf System
CDs won't play
Last time I used it it was fine but now all of a sudden at first when I put a cd in the system's display lights would be very dim and freeze until I would shut it off. Now the entire stereo will turn itself off and its clock is reset and put on demo mode when I try to read a cd.
But would a dirty cd or disc reader make the entire system shut down and reset? wouldn't it just.. not read it?
Posted on May 01, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
Maybe you should fix the cds or clean them or try to fix the disc reader in the radio.
My DVD Player ( ONIDA DFX-7100) is now unable to play any VCDs. I have tried many VCDs which were earlier working fine but now they won'tplay. The player keeps displaying the ''loading'' message and after...
Have you changed programs that you use to burn VCDs?
(Perhaps the program was updated?)
Perhaps trying a different program to make the VCD will work for you.
Also; when is the last time you cleaned the DVD player lens?
Mar 25, 2011 | Audio Players & Recorders
The cds won't play. Once you press play, the cd
Sounds like you have a powre supply issue. It could also be a display issue but if the display is working OK before you hit play I wouldn't think so. When you hit play does the display dim? If it does then the power supply is the problem. If not then the control board has a problem. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Onkyo DX-C340 CD Player
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Bose 3-2-1 Home Entertainment System
it must be the lens....
try cleaning it with one of those "cleaning cds" that have small brushes on their surface...
Mar 17, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
I have a jvc ux-g50 micro compenent system. Radio plays but will not open cd holders to play cds. Displays number (162)can you please help?
I have a jvc ux -g5. All of a sudden when i turn it on the cd tray no 1 ejects by itself and not closes when i push the button. From time to time it dispalys error 162. Addionaly not any cd fuction is corresponded. Any idea for solving the problem?
Dec 04, 2008 | Audio Players & Recorders
2002 Altima Factory Bose Audio ERR3
there are only couple options. pull radio and send to shop for repair, purchase used radio from good junk yard. or call dealer and see if there is a warranty on it. even though its 6 yrs old they may help. what they do at the dealer is an exchange
Nov 16, 2008 | 2002 Nissan Altima
How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Aug 13, 2008 | Audio Players & Recorders
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Feb 07, 2008 | Aiwa CDC-Z127 CD Player
Reading CD message
You can use a CD Cleaner as a first step, if it didn?t work the problem need an expert technician to clean the lens or replace it. Good Luck Toufic Malek
Jun 04, 2007 | Sony CMT-HPX9 CD Shelf System
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
JVC MX-KB30 CD Shelf System Logo
221 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
