Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My water dispenser is running and will not stop.
  • 1 more comment
  • joy_lewis Jul 03, 2009
    Hi Vic,
    Thank you for your help! The valve continues to buzz so apparently the switch is ok. How diificult is it for me to install the water inlet valve myself? Do you suggest a repairman?
    I appreciate your assistance!
    Kindly,
    Joy
    Hi Vic,
    The water dispenser is not buzzing unless I press it.
    Joy
    Hi Vic,
    Again, I truly appreciate your help. My refrigeration is a Whirlpool model # ED25DQ. Please let me know the cost and I will let you know if we would like to order it.
    Thank you so much,
    Joy
    President:
  • 1,136 Answers
Hi, There are 2 options that might be ha[[ening. Wither the water inlet valve has stuck open or the switch in the dispensor has gone bad.
Turn the water off to the inlet valve. Push the water dispenser button and see if you hear the inlet valve buzzing. Release the button and see if the valve stop buzzing. If the valve stops buzzing, the switch is ok. I hope this helps you. Please let me know if I can assist you later.
Vic
Posted on Jul 02, 2009
  • 1 more comment
  • Victor
    Victor Jul 03, 2009
    Joy, If the valve is buzzing even tho you are not pushing the dispenser lever, the dispenser switch is hanging up. If this is the case, you should have a repairman look at it. These dispensers can be very trying to get apart.
    Vic
  • Victor
    Victor Jul 03, 2009
    Ok, I am sorry if it takes me a bit to answer. My gmail is not working and I have to find your response another way.
    Turn you water source back on and see ifd the water starts flowing even thos the lever is not pushed.
    The inlet valve is not very hard to change. If you will get me a model #. I could look up the valve # and give it to you.
    Vic
  • Victor
    Victor Jul 03, 2009
    Here is the part# 2188542 and the cost is around $60.00.
    This is for model#ED25DQXAB00
    The number you gave me was a partial number. If you decide this is what you need and want, get me the whole number or go to www.repairclinic.com and type in the whole number. You cna find the rest of the number on a label in the fresh food section.
    Vic
I used the water dispenser and when done it wouldn't shut off. This is an inside of the unit dispenser. How do you fix this?
Your unit has a inlet valve that the supply of water flows to..This valve splits between allowing water to either the dispenser or the icemaker..This valve may be sticking open allowing water to keep flowing to dispenser..Google Model # w/problem to find location and part#..or call your local appliance repair company
Jan 04, 2018 | Samsung RF266AEPN Refrigeration :...
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
The water from the dispenser is running and i can't stop it how do you turn of???
The cause of the problem you describe could be ether water inlet valve or the water lever dispenser switch.Locate the water valve at the back of the refrigerator, open the water and take off both plugs from the valve. If the water flow want stop replace the water valve. If it will, replace the water lever switch.
Mar 24, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Electrolux EI23CS55GSI - Water Dispenser Will Not Stop Running
sounds like the paddle you push to dispense the ice and water is sticking,if there's a rubber pad there try moving it to see if it frees it up,if not it looks like you have to replace the whole part 242100018 go here to see it
https://www.repairclinic.com/PartDetail/Dispenser/242100018/3513417
Jan 18, 2018 | Electrolux Refrigerators
Water won't stop coming out from the cold water dispenser
The cold water dispensing valve can be stuck or defective. Sometimes jiggling the valve can make it stop running
Sep 30, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Water would not stop running into icemaker, now
The water inlet valve(where the water supply connects to the back) may have been staying open and now has burned so it don't work at all. . You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Mar 25, 2010 | Refrigerators
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
WATER RUNS OUT OF THE WATER DISPENSER ON THE DOOR OF THE SIDE BY SIDE
THe problem may be in the water valve for the water despenser,
you could try disconnecting the 2 wires on top of the water despenser side of the valve and see if that will stop it. IF not the valve may need replaceing, may be leaking thu water vavle when closed
Oct 18, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
455 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
