Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox XD100 that is showing a code J2
I have a Xerox XD100 that is showing a code J2. I know that this means the drum cartridge needs to be changed, however the copier is working just fine. Why should I pay for a new drum. Is there a way to reset the copier to keep using the existing drum?
  • 239 Answers
If this code just came on, you have about 2,000 copies to run before the machine completly will not run.
This machine will run so many copies before it end of lifes the drum unit.
In the old days, these drum units were serviced by the service representative.
Nowdays, the cartridge just runs to the end of life on the cartridge. Most cartridges will run for about 15k with 2k to use to allow the user to order a cartridge.
Even if the cartridge is still good, the cartridge is end of life at the maximum allowed copies on the crum.
If the problem still exists with a new cartridge, the service repair for this is more involved and needs a service manual and someone who knows what they are doing to do the service in diagnostics mode.
I have preformed this many times before.
The NVM settings need to be rechecked and the main board may need to be reset.
Very involved.
Place a Xerox service call to have this repaired.
Posted on Oct 23, 2009
I did change the Drum Cartridge with a new one still shows code J2 and it is not working, need help please.
Posted on Oct 17, 2009
    Problem Solver:
  • 11 Answers
No. The CRUM is integral to the Drum Cartridge. The only way would be to swap CRUM from a cartridge that failed for a reason other that it reached end of life.
Posted on Aug 02, 2009
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
We have a Xerox XD100 photocopier and we have a problem which according to our copier is ''J2'' - as we have lost our manual, we do not know what this means. Does anyone know what the problem is and how...
J2 means your drum has reached the end of life. It is a good idea to replace it rather than try odd things to reset it. Staples, Office Depot etc have those.
The drum and cleaning blades are pretty worn out by the time the light comes on.
Best place overall to order from online would be a business called "the parts drop". Google it and call Britt.
Oct 06, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
J1 Error, Changed a brand new factory-sealed toner, still getting J1 Error
Make sure you have the right code: J1 or J2.
one is for the drum and the other is for the ink.
Make sure the toner unit is for this model and not for a different model.
If the old modual is still available, check the connectors at the back and see if they are the same.
If anything else Call Xerox for repair. If the cartridge was bought through Xerox have your reciete available for warrenty.
If repairs still need to be made, A Xerox service call may be needed in order to fully repair the copier and warrenty the cartridge.
Nov 06, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Copies are light color and l like to know how to get darker
MOst likely the drum cart is the issue. There is a fine charge wire and grid on top of that cartridge that probably is going bad.
Aug 06, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
XEROX WORKCENTRE XL2120
J2 means the drum cartridge needs replaced.
Its next to the toner.
Jul 14, 2008 | Xerox WorkCentre XL2120 Laser Printer
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
J2 Error
check for a paper jam in the machine and in the paper tray, if no paper is found take out toner cartridge shake it slightly and reinstall. Also turn machine off & unplug. Let me know if you need more help.
Oct 26, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
448 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
