Question about Refrigerators
Ice filter stuck UKF8001AXXP - Refrigerators
  • itsmedino5 Jul 03, 2009
    It was very helpful, it took care of the problem.
    Thank You
  • 15,935 Answers
Twist counter clockwise and pull toward you.
Thanks for using FixYa :)
Posted on Jul 02, 2009
Ice maker, water panal on side by side refigerator not coming on when depresing handle
The water line could be frozen. Remove the water filter and see if it frozen. Also, see if the water dispenser works with the filter removed.
Sep 09, 2012 | Maytag MSD2572VEW (25 cu ft) Side by Side...
My GE GSL25JFPEBS side by side refrigerator stopped making ice. The green power light blinks indicating ice being stuck, but once the ice is removed from the mould, the problem starts all over again. It...
i am wondering if ice is constantly getting stuck or are the cubes smaller that the size of the mold? if that is the case have you tried replacing the water filter. The typically reason ice gets stuck in the mold is because the individual cubes (usually 7 or 8 per mold) are too small,the leading cause of that is not enough water in the mold
Also is water dispensing through the door with good pressure, if no replace filter but first check the pressure of the incoming water from house plumbing
Jul 29, 2011 | GE Refrigerators
Ice maker won't make ice after changing water filter
Have you tried adding a bit of water to the ice mold? Is their an ice cube stuck in the ice mold? If you have an ice cube stuck in there just heat the im with a hair dryer till the cube clears and fingers go around. Listen to see if you hear water going into the mold.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cannot unscrew housing around water filter seems stuck,
Open the freezer side and turn ice maker off. Leave freezer side open and try unscrewing the filter housing again. It will still be snug but keep turning and it will come off. Mine was stuck too but this worked. Good luck.
Jan 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
Kenmore hotspot ice gets stuck same spot
if the cubes are small the water valve may be bad. Also pop the cover off and see if there is a plastic tab laying loose in the cover . It should have 2 holding the center plastic gear on if only one is in the center the ice maker is bad. Also make sure to change your filter ever 6 to 8 months if you have one this will stop other problems.
Sep 23, 2009 | Freezers
Icemaker not making ice
If water is also not com out of dispenser then filter should be changed. If water dispenses but ice ice is not being made, the sensor arm or infrared sensor may be stuck or blocked. If sensor is OK then ice maker needs service.
Aug 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working
it depends on your model. was the i/m making ice b4 you replaced the wtr filter? if so, reinstall your filter again. i/m's normally rest or stop in the 2 o'clock position. are the teeth are stuck anywhere? it could be your i/m.
Jul 14, 2009 | Refrigerators
Not making ice
The filter does effect somewhat the flow of the water. For some people having problems with ice dispensing it may be as simple as lifting the metal shut off bar up and down. Then check the top of the ice tray to make sure no ice is stuck up there. When you move the metal bar up and down you should see the plastic dispenser that pushes the ice out turning or rotating. Hope this helps.
Dec 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Nov 27, 2008 | Refrigerators
Inconsistent ice maker
If you hit the ice maker or do you hit the water filter? if you hit the ice maker then I would say you need a new ice maker if you are hitting the water filter then you may have a frozen water line.
Aug 09, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
