Problem signature: Problem Event Name: APPCRASH Application Name: integrator.exe Application Version: 12.0.2110.8 Application Timestamp: 4ec65a41 Fault Module Name: MainControls.bpl Fault Module Version: 12.0.2110.8 Fault Module Timestamp: 4ec659c9 Exception Code: 0eedfade Exception Offset: 0001e2c0 OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 2057
If this is causing you to have crashes, the .exe is probably corrupt. It belongs to booster and certain tuneup utility programs ("Dachshund Integrator or TuneUp Utilities (version 2006, 2009) or Glary Utilities (version 3) or Glary Utilities PRO or Auslogics BoostSpeed"). If you have any of these programs installed I'd uninstall it and restart your computer. Then reinstall if you want to use the program still, though preferably after an update. I'd also clean your computer with CCleaner and remove junk files before reinstalling. This will clear corrupted files that might not have been removed with the uninstallation of the program. If you continue to experience this issue, install sandbox and make sure the program runs within sandbox. This will prevent any faults or issues with the program from interfering with your OS.
SOURCE: Problem Event Name: APPCRASH
try this
http://www.microsoft.com/downloads/details.aspx?FamilyID=b0c7136d-5ebb-413b-89c9-cb3d06d12674&DisplayLang=en
Hope It Solved Your Problem
Good Day
SOURCE: Problem signature: Problem Event
Try this
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
SOURCE: Close the Programe (Notice)
User permissions issue. Go to C:\program files\microsoft\fsx and find the fsx.exe icon. Right-click it, choose properties, and tick the check box for "always run as administrator". This process doesn't always work doing this from the FSX shortcut.
You have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Start
programs below.
