Question about Samsung Refrigerators
New refrigerator makes a knocking noise icemaker not connected
New samsung french door/bottom drawer freezer refrigerator makes a knocking noise every 5-10 minutes intervals. Why is this loud knocking noise continuing. Aqua filter is placed in refrigerator even though I do have icemaker turned off and not connected to water line. I unplugged refrigerator a couple of times but knocking noise still there. Please help if possible or is this part of refrigerator brand????
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 89 Answers
SOURCE: brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
Posted on Jun 07, 2009
  • 159 Answers
SOURCE: Knocking noise in refrigerator section
This will be a loose mount on the electric motor (tighten)
Posted on May 06, 2010
Daniel S
  • 4323 Answers
SOURCE: RF263 series Samsung Refrigerator just began
Hi
The sound comes when there is ice build up around the fan and the fan will hit it causing this sound. You can try to leave it unplugged for around 4-24hrs and also make sure that the area near the back is clear so that airflow can get through. If the issue returns then replace the thermostat. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 01, 2011
shane_mccown
SOURCE: water build up underneath deli tray drawer
Ok. I know why this is happening. Or at least in my case.
The coil for the Fridge is stored behind the center panel when looking directly into the the Fridge.
What happens is the drain for the coil becomes iced up. It then wont drain and when the fridge goes into defrost mode the melted water will run out of the bottom of the center panel. This is difficult to see due to all the shelves in the way. i noticed this because I could see ice through the vent holes in my center panel.
To fix this:
Take all the items out of the fridge.
Take all the shelves out so the center panel is exposed.
Remove the 3 screws at the bottom of the panel and single screw under the cover of the shelf rail. (This one is a little hidden) pop off the plastic cover first.
Now you can pull the panel off.
(Note. This can be a little difficult to get off because you have a ton of ice behind there keeping it stuck to together. Just ease it off as much as possible.
When you get this off you'll most like see alot of ice in the tray that the water is draining into. chip this ice away and then I used Hot water to pour into the drain. I would then use a shop vac to **** the water out and put in more hot water until the ice plug is removed and the water can flow freely to the drain pan under the fridge.
That is it. I own this fridge and I've been tired of having to **** water out of fridge with a shop vac every 2 weeks. So I decided to resolve this myself.
*disclaimer. I'm just a DIYer not a Samsung repair person.
Good Luck and I hope this solves your issue.
Posted on Aug 25, 2012
I have samsung french door refrigerator 2 door 2 drawer with vibrating a noise. I have removed the back panel and the noise does not seem to be cominng from this area. any suggestions.
We have a different model Samsung, and I've heard a vibrating or buzzing noise twice. First, if the water filter isn't an exact fit (even Samsung's filters rattle), it will rattle. Second, if either of the ice makers gets stuck or jammed, it can make a vibrating noise. If our freezer drawer isn't making a good seal, ice will build up under the drawer or in the slides. Ours makes more of a humming noise, when this happens. Other areas to check: something stuck in the runner of your drawers or shelves (if yours pull out). There are also vents that draw air in and out of the cooling unit, and things in front of them may vibrate or rattle, too.
Jul 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Rfg298aars ice maker
My Samsung French door fridge #RF267abbp makes a knocking sound coming from the ice maker. The knocking lasts for about45 minutes and continues throughout the day and night, It is very annoying especially at 3 am.
Oct 02, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
Fan is making a loud noise. When I open the door, the fan stops.
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Apr 23, 2011 | Samsung RF265AA Bottom Freezer French Door...
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
May 05, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge makes loud noise every ~10 minutesq
Does it have a ice machine it it? If yes, that means it is very normal mine does it thats what happens, if no... Then go get a new one, and bring it back. You may have a loose screw
Oct 08, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
675 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
