I am squeezing the trigger and water won't come out. Also hand tool water won't come out.
SOURCE: Model 1699-1 ProHeat Clearview Plus -water and
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
SOURCE: Will not let any water out when i squeeze the
Try squeezing the trigger a few times repeatdly. This usually works for me.
SOURCE: When using the floor configuration,
The trigger on the handle for tthe floor configuration has become loose or broken. When you squeeze it, the action pulls a rod that runs down the length of the shaft and goes into the base and allows the water to spray. You need to check and make sure that it has not come loose. To do that means that you have to take the unit apart or take into a bissel service center. To take it apart you need ot unplug it and lay it down, take the tank out of it and take all the screws out of the base. You can then seperate the top of the base from the bottom and you can see the rod coming from one of the wheel areas. Squeeze the handle trigger and see if it moves.
SOURCE: Bissell Proheat 9200-H, won't pick up water to bottom tank, except by hand tools.
this could be the problem
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
