Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Communication Error and Bad Autofocus in Canon 17-85mm lens
Hi
I´from PERU
my 17-85mm canon lens
don´t autofocus well, but
the motor works
and sometimes show an error in the display
and says that the communication with the lens is not good
I send to repair and tell me that its the flat cable
and have to replace it but it difficult to find.
Please tell me if that have sense or no
thks!
    Dedicated:
    Visited the website for 20 consecutive days.
  • Canon Expert
  • 408 Answers
Clean both the lens's contact and body's, if corrosion use nice emery paper.
Posted on Sep 10, 2017
SOURCE: autofocus function will not work on Canon 17 40mm 1.4 EF lens
Since the problem is limited to this lens, I highly doubt that you would have to replace the cameras AF sensors.
Since you only have the problem with this lens, I am afraid that you will have to get the lens repaired. Is the lens also 3 years old? Did you get it with MACK extended warranty?
Sometimes, Canon do these kinds of repairs for free, if they discover that there was some manufacturing error that caused it to fail. So be sure that you get it to a certified canon workshop.
I hope this helps,
/Chris
Posted on Jan 20, 2009
  • 12 Answers
SOURCE: my canon 18-55 IS lens cant autofocus
try clean the contacts you're self by using an eraser or cleaning pencil.
did u check the Exposure Meter is working correctly?????????
Check that now..........@ reply to my mail..
Posted on Nov 05, 2009
Testimonial: "Hi Seyapathum! I tried cleaning it. and also the body. But same thing happened. the meter is still working. coincidentally, the body's curtain"
  • 77 Answers
SOURCE: Auto focus not working?
1st u reset the factory setting and then u see the lense is correctly fitted or not and the autofocus option is working or the manual focusing is there or not
Posted on Dec 14, 2009
  • 31 Answers
SOURCE: lens not communicating with camera
contact problem or lens diaphram blades problem. First try to clean the contact with the pencil eraser. If the problem isn't solved. send it to canon it should cost you about 100.00 to repar.
Posted on Mar 30, 2010
  • 63 Answers
SOURCE: Will the Rokinon 85mm 1.4 lens autofocus with the
No!
The Rokinon is like the Nikon 85mm AIS lens and is manual focus only..
Hope this helps, Andrew
Posted on May 20, 2010
How to fix the communication error canon 1.8 50mm
Turn camera off, remove lens
Replace lens, turn camera on.
To help prevent it from happening again, you can try cleaning contacts on both camera and lens.
Aug 30, 2013 | Canon EF 50mm f/1.8 II Lens
Canon Rebel XSi won't autofocus and makes grinding sound
There is nothing that auto-focuses except the circuit in the body - all the motors, gears etc. are in the lenses. If this is a 18-55 lens then more than likely the long shaft gear has broken teeth - a very common problem.
Mar 30, 2013 | Canon Rebel Cameras
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 UC Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts but still get...
From working with third party lenses in the past what I've found is that Canon doesn't give up the "chip" technology so the older lens can not talk to the newer cameras. I suspect that Canon does this to promote their lenses over the competition. You might be able to send the lens to Sigma and have them re-chip it and have a great lens again.
Dec 26, 2010 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Canon ef 50mm 2.5 macro autofocus broken. Buy new or have it fixed ?? can u advice ?
I thought mine was broken but i cleaned off the copper tips on the bottom with a clean eraser very gently, and afterwards i put on the lens and it worked. I would give that a try if you have not already
May 10, 2010 | Canon Normal EF 50mm f/2.5 Compact Macro...
Dec 14, 2009 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Autofocus not working
If you don't know how to fix it yourself send it to Sigma UK (01707 329999). They are quite resonable charges for that sort of fault. Their website give a price guide depending on lens and fault. Steve
Jan 31, 2009 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Autofocus function will not work on Canon 17 40mm 1.4 EF lens
I hope this helps,
/Chris
Nov 24, 2008 | Canon 35mm f/1.4L EF USM Autofocus Lens
Autofocus is stuck on Quantaray 28-200mm F3.8-5.6
NEVER open it up. You will destroy the dust seals. Have Canon repair it.
Apr 15, 2017 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
2,380 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
