Question about Ruud Matching Split Air Conditioner
Fan will not run,how do i test run capacitor - Ruud Matching Split Air Conditioner
You need a volt ohm meter that will check uF, or a meter specific for capacitors. a lot of fans require a 5uF capacitor. they are very cheap to buy. If your fan gets hot, but doesn't start and the blade turns freely then its probably your capacitor is bad. Just kill all power to outdoor unit and pull the leads off on the common and fan on the capacitor and hook them up to the new on and the fan should start.
Posted on Aug 15, 2009
The outside fan starts and runs, but after a few minutes the fan quits running. I replaced the fan capacitor and the problem persist
check and test motor and relay the capacitor is used as a booster to start fan not needed to keep it running
Aug 31, 2017 | Heating & Cooling
Condenssor fan moter not working
The condensor fan is usually a capacitor start capacitor run motor.To test i switch the unit on as normal then carefully flick the fan around in the direction of rotation (you may have to take the grill off) to do this,do not use your hand! If the motor starts to run it will be a faulty capacitor, do not leave it running for long as it will not run at full speed and will trip on thermal O/L or burn out.This is a common fault on AC split phase motors that use a capacitor for either starting or start and run.
Feb 03, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Uaka 024JAZ condensing unit comes on, fan and compressor start up, fan remains on, compressor shuts off in appx 1 min , pressures appear to be headed to normal op range. I did not see a run cap for this...
This unit uses a dual run capacitor. There is no start capacitor involved.
The dual run capacitor is possible weak, also check all the electrical connections for tight fitting connections with can cause motor/compressor overheating.
To test a capacitor properly you need the proper test meter capable of reading uf readings(within 6% of the stated rating on the capacitor) "C" common to "F" fan and "C" to "Herm" terminal, the higher rating for compressor and the lower for the outdoor fan. [(example= 25/3uf 370v) 25uf=compressor, 3uf=fan motor.]
Oct 01, 2011 | Ruud UBHC Air Conditioner
The fan in the compressor for the HVAC unit quit running last night this morning after 2 attempts it started and ran fine , cooled form 76 to 72 in about 45 minutes, but when I tried to start it again the...
Replace the fan motor and capacitor. If you want to go the cheaper route, change the capacitor first and try to run the unit. The cap. is what gets the fan motor running on start up. Another way to test it is to manually turn the fan bade and while it's still turning, make sure your hands are clear of the blades and turn the condensor on. If the fan runs normally, then it's your fan capacitor.
Jul 02, 2011 | Amana Heating & Cooling
Weather king model 13pja36a01 Heat pump The outside fan runs slowly, compressor starts then immediately stops. I replaced the run capacitor, I believe this might be the fan motor going bad but I...
If you have replaced the run capacitor and the fan still is running slow you definitley need to replace the motor no doubt. you can go online to Grainger.com or find one by your house. Your compressor is going off immediately because high pressure thats a good thing. Get a new fan and a new capacitor and you should be good.
May 09, 2011 | Weather King 10AJA3601AH Air Conditioner
Fan wont run
Hello, I think your running capacitor is leaking, or your fan is busted,. yo need to check using a volt meter to test the running capacitor. if the capacitor is ok yo need to replaced the motor fan. ask a technician to help you. thanks
Apr 25, 2011 | Frigidaire FAC126P1 wall/window Air...
The fan on our heat pump is not spinning. If we a...
Is the compressor running? Take a look at the contactor in the outside unit and see how it looks and if it is pulled in energizing the fan and compressor. If the compressor is running then check for voltage at the fan. If you have power at the fan and it isn't running then turn the power off and check the capacitor. It may have just 1 for both the fan and compressor. If the capacitor is ok then the fan motor could be bad. You will need a multimeter with a capacitor check function to test the capacitor. Hope this helps. Let me know what you find.
May 21, 2010 | Heating & Cooling
Fan on outside unit will not turn on, will run once you give it a spin with a screwdriver however will not turn on by itself. Changed the fan and the capacitor both out with new ones, i am baffled!
That is wierd. If the fan and capacitor is the same as the old one. Although I'm thinking of capacitor issue, you should take out the fan and capacitor and test it.
I hope this helps.
Jul 01, 2009 | Heating & Cooling
Fan will not start on it's own
The fan only has one capacitor. The other two are for the compressor, one is a start capacitor and the other a run capacitor. A schematic should be on your fan motor telling you witch two wires run to the start capacitor for the fan motor.
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Ruud Matching Split Air Conditioner Logo
121 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
