SOURCE: dell optiplex 170L hard drive recognition
Ms Driver gets flaky sometimes. Get New driver from Dell Downloads.
Contact Dell Support for more INFO
SOURCE: in my dell desktop optiplex 330 hard disk is
Is it a BIOS password or a HDD password? If it's sewt in BIOS, you could try to reset the BIOS to factory default (which should remove any BIOS passwords) If however it is a HDD password, it is a bit different.. you may need to restore your sytem (low level, high level formats, then reload your OS sorry but you likely lose all your data..What OS do you use? there are programs that can possibly give you a boot cd depending on whether your system is fat32 or NT.. NT is more complicated because fat32 will not read NT BUT NT will read fat32.. IF you have the ability to restore your OS then first try to do a complete restore with backup.. that way you may be able to save most of your datafiles.. if you have never accessesd the pc then just try a destructive system restore (will low-level, then high-level format the HDD and reinstall your software without any SW passwords..
First thing I would try is to get into the BIOS and unset any passwords there.. If you need more help you can try to contact me [email protected] with more information
SOURCE: have a dell optiplex sx280 and its giving me the SAA primary
If your hard drive has failed a) you need a new one, b) you will have to reinstall the Windows system but c) you will have lost anything you stored on the computer. This is why we encourage people to have backup systems.
SOURCE: Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
SOURCE: i have a dell optiplex and the hard drive has been
Did you replace the old hard drive with a new one?
Check the connections on the drive itself. When you plugged the new one in, there should have been two cables you plugged into it. 1 small one that goes to the motherboard (called the SATA cable), and one wider one which comes right out of the power supply. If either of these is not plugged into the hard drive, you would get a message that says "could not find drive".
Check your connections and try again. If they're ok, then write back with as much detail as you can provide.
