Question about Carrier Heating & Cooling
What is the test to find out if run capacitor is good
  • 2,418 Answers
What types of test equip do you have. I use an old analog meter and watch the needle move. Go to your neighbors house and ask if you can plug it in to his a/c. Or go to home depot and buy a meter that reads caps. 45 50 dollars. You cant read them with just a electronic volt/ohm meter. Does it look swelled or burnt? Any wiring burnt, what is going on to make you think shes bad? repost let me know.
Posted on Jul 02, 2009
Freezer chest not cooling but Compressor is running
Unless you have a microfarad capacitor meter, you won't be able to check the capacitor. Make sure the evaporator fan motor is running. You may be low on refrigerant.
Feb 22, 2015 | Refrigerators
How do i test capacitors on rheem 90-21592-01?
assuming you dont have a multimeter then get a insulated screwdriver and short the post making sure you pull the power to the unit a strong spark means it is good and weak spark means bad no spark means bad and if you use a multimeter the take a reading using the unside horseshoe looking on multimeter is should get a number each time you charge the capacitor match the number
Aug 17, 2014 | Heating & Cooling
How do I test the capacitor on a sears saw 113.199250?
I don't have the same band saw like yours. To check if the capacitor is bad, start by removing the blade for safety
Turn on the saw and spin the shaft by hand. Move hand away immediately. A good working motor will begin
running as you turn the shaft. If this is the case, you need to replace the capacitor.
Dec 02, 2013 | Craftsman Sears Radial Arm Saw Motor...
With the Air set to onor auto, i get power to the unit but it will not run, i hear like a starting noice but the fan will not move
Allow the motor an hour to cool off. Then try to restart via normal method PLUS try spinning the motor by hand. If the motor starts to run normally for a few minutes, disconnect the power, remove the capacitor, and take the capacitor to your local HVAC parts warehouse to have them test it for you. If the capacitor tests "failed", replace the capacitor. If the capacitor tests "good", you will need to replace the motor (replace the capacitor when you replace the motor).
Hope you find this to be very helpful to you, moving forward. :-)
Jun 11, 2010 | Ruud Central System Air Conditioner
My microwave is running but it is not heating the product
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Sep 13, 2009 | Microwave Ovens
Not heating the goods in the microwave the light and power is on but not heating or cooking the goods
You can also order from MicrowaveSvc , they also provide parts.
Sep 11, 2009 | LG Microwave Ovens
Everything runs but food does not heat up
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Mar 27, 2009 | Frigidaire PLMV168 Microwave Oven
It runs but does not heat
Mar 24, 2009 | Panasonic NN-P794SF Microwave Oven
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
