Question about Garden
Replace pull cord Big Wheeled weed EaterString
Replace pull cord Big Wheeled Weed Eater String Trimmer
    Problem Solver:
  • 13 Answers
First, remove the recoil assembly but dont disassemble!
You'll need about 3 1/2 ft. of the same size rope. Tie a knot into one end of the rope. While holding the pulley in place observe the direction the pulley moves when rope is pulled. Release pulley and cut and remove old rope. Continue winding pulley in direction rope would pull it. Do no wind too tight. Line up holes in recoil housing and pulley then push rope through pulley and out housing. Tie on handle and install recall in reverse order.
Posted on May 06, 2010
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
How do I change the string on a wheeled weedeater brand trimmer
Purchase precut pieces of string. Check the dealer or or big box store for the correct part. The precut string is easily clipped in. Remove the old piece by pushing back and lifting up on the piece until it comes loose. Put the new piece in the slot and pull it forward to seat it. Repeat for the other side(s)
Oct 19, 2014 | Weed Eater Wheeled Weed Trimmer 961720006...
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Mar 25, 2012 | Toro& Electric String Trimmer
Pulling string on weed eater does not want to turn
It's possible that the engine has seized if the pull cord won't turn the engine over. Remove the starter mechanism from the engine and try to turn the flywheel by hand. One or more of the mounting screws may be hidden under a decal or other label. If the engine won't turn at all, remove the muffler and check the piston skirt for bad scoring--which usually means either dirt inhalation (bad air cleaner) or running the unit on straight gasoline. Either of these conditions require replacement of the cylinder, piston and ring(s) plus labor if you farm out the repair. Weigh the approximate cost of up to $150 against a new trimmer. Hope this helps!
Jul 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
326 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
