When i **** disc to run a program for a wireless lan usb adapter screen is blank it does not run first time it was inserted it came up with camera,auto play see files etc. etc. but no start driver thanks bear
Just try to find another computer with optical drive and copy the whole CD content to a flashdrive, it might be the optical drive on your computer is broken or dirty or the CD itself might need cleaning. After you copy the Whole CD into a flashdisk, direct the dialog to your flashdisk!
Good Luck!
If you are streaming through Blueray check your setting on the Blueray for WiFi access. If you are going through a computer then check your Network settings for the internet.
It might not need for WIn8 to detect the adapter. when that screen appears cancel/close of otherwise kill the process and see if the adapter is recognized in Device Manager without any error icons.
Make sure you have installed all of the correct drivers before inserting the wireless device. The drivers are located on the CD you received with the product or can be downloaded online @http://www.samsung.com/us/support/downloads
what you can do is if you got another computer with internet connectivity then go on to the usb adapter make site and there sould be a section for you to download the driver software
You can run HP update to download and install drivers on your PC/Laptop, or run Microsoft update too.
Your HP PC came with a tool called Recovery Manager, Click the vista start menu and in the search bar type (Recovery Manager) without the parenthesis and it should display programs like RECOVERY DISC CREATION and RECOVERY MANAGER , please select the RECOVERY MANAGER an if you have VISTA USER ACCOUNT CONTROL turned on you will have to allow the program to run. OK, once program launch, select the advance Options and click on HARDWARE DRIVER RE-INSTALLATION and click next. follow the screen instructions to re-install the driver or drivers. Make sure you are not running any other program when using recovery manager. GOOD LUCK
You can connect to the Internet using your DSL wireless router by several methods.
1. If your HP has a LAN port the you can connect to your wireless router with a LAN cable (provided you have a spare LAN port on the router.
2. You can use a USB wireless adapter to connect to the wireless router.
3. You can use a PCMCIA wireless card to connect to the wireless router.
Both the wireless USB and PCMCIA wireless adapter are approx. $50, my preference is to use a PCMCIA adapter, it leaves the USB port free for other devices,such as USB memory sticks, especially if the laptop has only one USB port.
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
click on the start button, all programs then go to accessories and then the program compatability wizard see if it will run from there if not try start, run then click browse then on the right hand side my computer, then click on the cd drive then the setup one of these should work
