Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Won't start after killing the motor
I shut off the mower for a few seconds, and now it will not start, this is a brand new mower only had since may
  • 2,418 Answers
May need more info. Check for a seat switch to have came unpluged (wiring) this is a safty thing. You have to have your foot on the brake as you sit in the seat to get it to crank. repost if you need more help.
Posted on Jul 02, 2009
    Problem Solver:
  • 6 Answers
I have a Craftsman 17.5 42 cut rider that is not getting gas to the carb. you pour gas into the carb and it will start up then just runs out of gas and quits. Is it fuel pump or carb ?
Posted on Jul 03, 2009
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
How can I shut off the motor? Is there a kill switch?
there is supposed to be a kill switch on side of engine. just follow the cable down to engine. it may be broke or just frozen. the cable that shuts down mower. Good-Day!
Jun 07, 2014 | Garden
Hu700f won't start
My huskuvarn will not start put a new carburetor and a magnitude coil on it it is brand new and will not start it is a 700f husqvarna any suggestions on it plus like I said a new coil and it is not sparking and not starting please help me out
Feb 18, 2013 | Husqvarna HU700F 160cc Gas 22-in 3-in-1...
My lawnmower won,t start
Three things I know to check. 1. check for broken kill switch wire or loose connection on same wire. 2. check for loose or corroded wires on switch. 3.If this unit has a stator and mag polish the surfaces of both and check clearances.
Jun 21, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
The mower will start and die in a few seconds wont restart unless i release the kill handle and pull it down again i can here the switch click but think i need a new switch i ohmed it out test ok but that...
This sounds like a fuel flow problem and not ignition kill switch, especially based on your ohms test. Fuel filter (screen) gets gummed up inside the tank. For testing you can supply outside fuel to the carb inlet port.
Jun 04, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I purchased a 550 series mower last year. It worked great. I used it a week ago and it worked great. Took it out today and it starts right up but won't run for morethan 5 seconds....starts right up...
Hi, remove the bowl off the bottom of the carby and clean it out. My best guess at this stage is that you have water in the bowl. Hope this helps, regards Phil.
May 25, 2011 | Poulan Push Mower
Toro self-propelled mower will not start. I thik it is the kill switch. What can I do now? Can I bypass?
Yes you can just unhook the wire and see if you have spark then, only thing is if it is the kill switch then you will have to replace it or you won't be able to shut your mower off unless you choke it but that will eventually wash the oil from cylinder causing premature cylinder wear, hope this helps you
Apr 17, 2011 | Toro Lawn Mower With Toro Power Tools
Lawn mower does not run.
Needs a new diaphragm. Its between the carb. and gas tank. It collapsed and doesn't allow enough gas to carb. to keep motor running.
Apr 10, 2010 | Mtd 22" Yard Machine Push Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
114 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
