Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Have a2008 fatboy put on a set of big radius when letting go of thrortle it pops what causes it to do that
  • 116 Answers
Your fuel mixture must be remapped with all pipe changes you can pay the harley shop around $200 for them to download the proper fuel mapping or buy the vance and hines fuel pak and download settings for your application note fuelpak setting downloads not always accurate harley does downloads on dyno the only way to insure accuracy
Posted on Dec 30, 2009
  • 40 Answers
Decel pop is caused by a lot of things! if you have big pipes; ie:drag you need baffles to tune the exhaust wave; theoretically upon decel instead of exhausting you are actually allowing reversion- which allows exhaust to actually renter your engine and try to get compressed again; very bad for performance, etc big pipes are cool but need proper baffling and tunage to be useful; may be too lean possible fix w/ supertuner/ dyno runs; I like "lollipop" baffles you can make for under 5 bucks and tune as you need; thats what I run on my 95HP sporty; Have Rinehart true duals on my Road King and via ecm tuning you can really dial it in. F/I is great but you need to "pay to play" no quick fixes like in the carb days; really need a dyno or some sort of computer tuning capability; I recommend Super Tuner rather than the piggyback setups; more expensive at first but wont fry your ecm either. A good dealership will be able to tune it right the first time in under an hour...sorry for the lenghly reply but I see this question all the time...T
Posted on Jul 07, 2009
How big is mercury
Mercury has a radius of 2,440km (The radius is the distance from the centre to the edge).
Jun 15, 2014 | Video Game Consoles & Games
What's the torque setting for the bolts in the radius arm on a toyota landcruiser
10 would be the grade of the bolt. google tensions for diameter and thread pitch of your bolt
May 04, 2014 | 2007 Ford Sport Trac Limited
Install big radius
Hi Anonymous, install big radius what?
Apr 05, 2014 | 2006 Harley Davidson FXDCI Dyna Super...
Differential
do your homework here, otherwise u will just be replacing parts. tire pressure,circumfrance and same brands are critical. as well make sure the ball joints etc are in good condition. by taking out the driveshaft your mechanic has only eliminated the driveshaft u-joints as a possible cause. you have front u-joints, front ball joints, sway bar links, springs, radius arm bushings that may be causing the noise. the pop is caused by something worn that is being put in a bind while turning. sorry i am no help here but your mechanic needs to go further then taking out a driveshaft and confirming the axle is bad... a bit more to it than that. wish u luck.
Aug 29, 2012 | 2002 Mercury Mountaineer
How big a tire can I put on a 1994 f150 2wd?
31/10.50/15 on a stock pickup. anything bigger will rub on the radius arms and catch the bottom of your bumper when you turn
Oct 18, 2011 | 1994 Ford F150 Styleside Supercab
Hello, My 2011 fatboy lo runs very hot. I have Vance and Hines big radius and screamin eagle stage one kit. It runs hot but it runs awsome. i wanted to put an oil cooler on the bike but was told to leave...
There's hot and there's too hot. Heat is one of the factors that shorten the life of an engine, especially an air cooled engine. You bike is equipped with the oil jets that help cool the pistons. If it were my bike, I'd take the bike to a known good high performance shop that had a dynometer, an exhaust gas analyzer, and a good mechanic that knew what he was doing with both the bike and the dyno. I'd have them run the bike up through the RPM range and check the fuel-air mixture ratio at various rpm levels. If the bike is running too lean, it'll run hot. Lean is mean but too lean is bad. The mechanic may can richen the mixture up just a bit, say from 14.2:1 to 13.7:1 and reduce the heat while maintaining the performance you want. It's worth a try.
Good luck
Steve
Jun 01, 2011 | 2011 Harley Davidson FLSTFB Fat Boy...
Mikuni jetting
If it's the Sreamin' Eagle Mikuni, it should come jetted close enough to take your bike to someone with an exhaust gas analyzer. That's the best way to get your card jetted correctly with the extensive amount of changes that you have made on this bike. I would advise that you take the bike to someone that has a dynometer that is equipped with an EGA and have the run the bike up. I would not want the mixture to exceed 14:1 at any time and preferrably run about 13.5:1. It's a bit on the rich side but it will help keep your engine running cooler. I've installed the carbs before but I cannot remember what jets they had in them. Sorry. Good Luck.
Jan 21, 2010 | 2003 Harley Davidson FLSTF Fat boy
I need to know what a complete lower arm set up looks like on a 1990 Riviera. It's in this one guy's shop & he's saying that I need a new radius arm. But my friend who works @ a Chevrolet dealership...
It is My Opinion that A BALL JOINT Broke and it MAY Require A "CONTROL ARM" To Repair it Properly, RADIUS ARM is NO Term Used in the AUTO Repair Field in my 25+ Years. Getting a Picture of it Will be Hard as Most Repair Manuals Show Partial Pics. But I Can SAY That it LOOKS LIKE The SHAPE of an "A"
Aug 18, 2009 | 1990 Buick Riviera
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
Lands Phones Logo
110 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
