Question about Sewing Machines
Seting the bobbin tension on brother xl-5600
How do I correctly set the bobbin tension on this machine? I inherited this w/o a manual. I'm trying to do a straight stitch and while the front looks great the back is loose and loopy.
  • 111 Answers
Loopy underside means upper tension and or threading is wrong
Posted on Jul 08, 2009
Skipped bottom stitches
try changing the needle
make sure the bobbin is inserted correctly
make sure the bobbin is not warped
make sure the bobbin is turned the right way in the bobbin case
make sure the top tension is adjusted correctly
make sure the top and bobbin thread is the same
Feb 01, 2013 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-2600i upper tension too tight even when set to ZERO
I agree with you to take it back & buy another brand
Sep 30, 2012 | Brother XL-2600
Can you tell me what the initial tension settings should be for a Brother xl2600i?
try a new needle
rethread the machine top & bobbin
make sure the bobbin is inserted into the bobbin case correctly
it's also possible that the machine could be slightly out of time
& a sewing machine technican would have to check the machine
to see for sure
Aug 06, 2012 | Brother XL-2600I
Bobbin xl5130 is gathering but the stitch on top is fine. how do i adjust the bobbin tension
to adjust the bobbin use the top tension
also try rethreading the machine top, using every thread guide & bobbin making sure to insert the bobbin correctly into the bobbin case
also try changing the needle
May 22, 2012 | Brother Sewing Machines
How do i set the tension on my brother xl-3010 sewing machine . the bottom thread is always in knots but the top stitch is perfect. i do not know which wheel to turn for the bottom tension.
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
May 31, 2010 | Brother XL-3500
Thread is catching & breaking somewhere inside the machine before it gets to the needle. brother XL-5600 machine
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
Apr 10, 2010 | Brother XL-5600 Mechanical Sewing Machine
My four-year-old XL3500 seems to have a tension problem. It was sewing fine until after I refilled the bobbin, changed thread twice, and did some zigzag stitching. Now the top stitch is not correct; it...
according to the diagram in the manual, the upper thread tension is set by the wheel/knob on top and just to the right of the thread take up lever and thread guide. If you don't have a manual, go to www.brother-usa.com they have a downloadable manual for your machine.
Jun 04, 2009 | Brother XL-3500
I have a Brother XL3010 and I can't get the tension set right. The bottom thread keeps making loops. What am I doing wrong? thanks stampinjean
try and adjusting your bobbin case tension ,the little screw on the bobbin case. with bobbin in case hang by thread if it drops easy tension is to light cotton should be able to slightly move through the case. hope this helps reguards
Feb 26, 2009 | Brother XL-5340 Mechanical Sewing Machine
Sewing Machines Logo
231 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
