Replaced fuse, plugged back in, ran full cycle, took clothes out and wouldn't start again. fuse out and so is the thermistor
Lots of videos here about that problem.
maytag dryer thermal fuse replacement YouTube
Which thermal fuse. The one on the heater or the one on the lint filter housing? If it was the one on the heater did you replace the thermostat too.
Is the dryer vent blocked, has too many elbows, or too long or otherwise restricted, or is the dryer overloaded.
https://www.youtube.com/results?search_query=maytag+dryer+thermal+fuse+replacement
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
SOURCE: dryer won't run
I would say that maytag has a problem with lint collection. That is why so many thermal fuses blow and why so many people just bypass this "saftey" device rendering it more dangerous.
I would advise anyone with this model Maytag dryer to pull the front body panel and clean the lint out and then replace the thermal fuse.
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
SOURCE: Maytag performa Keeps blowing Thermal Fuse. Vents
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
