Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
When I type the letter p it apears 3 times ppp ?
I am having the same problem, but with a number of letters. How do I stop this from happening
Posted on Aug 14, 2009
I cannot get www.walmart.ca/en.ppp. Everyone is asking how to do it but no one is answering. this is ridiculous!
to get the walmart protection plan do not just type ppp at the end of the address you need to type in product protection plan
Apr 18, 2011 | Cameras
Tip
How do you configure Multilink PPP on Cisco Routers
How do you configure Multilink PPP?
Given that the two sites that are connecting via Multilink PPP communicate with each other and coordinate the configuration, configuring Multilink PPP is easy. Here is a sample configuration of 3E1 circuits being bonded to form a single 6Mb Internet circuit:
controller E1 4/0
framing NO-CRC4
channel-group 1 timeslots 1-31
description Connect to OtherSite#1
controller E1 4/1
framing NO-CRC4
description Connect to OtherSite#2
controller E1 4/2
framing NO-CRC4
description Connect to OtherSite#3
interface Multilink1
ip address 1.1.1.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial4/0:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/1:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/2:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
This configuration is from a Cisco 7200 router that has Qty 1 Controllers E1 interfaces (plugged into module 4). These E1 controllers create the Serial4/0:1, Serial4/1:1, Serial4/2:1 interfaces that are bound to the multilink group #1, and other serial interfaces (Serial4/3:1, Serial4/4:1 and so on...)
It is the multilink1 interface that is actually the single combined interface that really has the “6Mb” of bandwidth, and that is where you would apply all of your “normal interface configuration” for this 6Mb connection that connects to the Internet. You can see how the multilink 1 interface has an interface number that matches the ppp multilink group. On that multilink 1 interface, you have the IP address for this link, an ACL on the interface, firewall, NAT, or other router interface commands.
By using the multilink interface, you are able to bond all three of these E1 interfaces into a single router interface — very cool!
To verify that your multilink interfaces are up and running, you can use the show ppp multilink command, like this:
Router# show ppp multilink
Multilink1, bundle name is OtherSite
Bundle up for 3w4d, 89/255 load
Receive buffer limit 85344 bytes, frag timeout 1000 ms
10518/6985 fragments/bytes in reassembly list
21651 lost fragments, 3287247349 reordered
17098/8879018 discarded fragments/bytes, 18 lost received
0xA990C7 received sequence, 0x7F6AA8 sent sequence
Member links: 3 active, 0 inactive (max not set, min not set)
Se4/0:1, since 3w4d
Se4/1:1, since 3w4d
Se4/2:1, since 3w4d
Router#
The key to configuring Multilink PPP is the multilink interface, the ppp multilink protocol on each router, and the ppp multilink group x command on each interface. Multilink PPP isn’t a difficult router configuration to set up, and it is extremely valuable when you need multiple circuits bonded into a single circuit from a single provider.
And for sure, you can just add multilink interface to be routed using OSPF, PBR or any other routing protocol.
on Jan 12, 2010 | Computers & Internet
When i type a letter A appers AZ, or letter s apears sxw ,all letters on 4th line on my keyboard when i click apears like that AZ SX DC FV G H JMU K, L.
first try a good cleaning with canned air then try it again if no improvement you might wanna try lifting your keyboard up and try to have the cable re-seated into the motherboard they can come ajar over time if none of those work it could be a keyboard failure new ones go for around 40-50$ new so try those tips you can also use an external in the mean time good luck
Nov 26, 2010 | Computers & Internet
My Dell keyboard is typing french symbols,how do I change it back to english
if you have windows XP follow these steps :-right click on Taskbar-Toolsbar-here check the language bar(should apear in your case french) -right click on the Fr(that apear)-settings -here you will see French keyboard-click Add and select EN-english -than OK and your keyboard should type english letters/
Dec 09, 2009 | Dell 0Y3740 Keyboard
How to put a application to a samsung sgh -d900i
first you need to download 3 programs & then use from them.
1.JADMAKER for make jad files from jar aplication files.
u can download it here :
http://www.softpedia.com/progDownload/JADMaker-Download-8344.html
2.u must dowmload an uploader software foruploading jad file to ur phone
(its easy to find by searching in google)
3.u need to softicppp software too!
follow this path :
install all programs
Load Softick PPP gate and click cancel on the missing USB file prompt as it is not relevant for this activity.
Type in from the standby screen of your phone; *#52828378# and select OTA type setting as Serial OTA bearer.
From there, go down to Serial test and choose PPP up
From the computer, go to usb and double click on the serial port.
Back on your phone,select usb,you will be loading your files with a usb connection.You will have returned to the serial test menu if all has been done right.On the computer, load Samsung XXXX uploader and load a .jar file .On your phone, you now need to push Serial Download.If your phone has not crashed, you should see a dartboard, the java logo and a small progress bar.The game will automatically start downloading.When the game has been downloaded, it will start automatically.Make sure you turn off PPP from Softic as the phone is restarting. Once the phone has restated, activate PPP again and press Yes on prompts to serial connect and try again.If it keeps crashing, try re-reading the instructions. Or your phone is not compatible with the game.
Sep 25, 2009 | Samsung D900i Cell Phone
Printer message apears "change tray 1 plain letter" when i press print. will not print until i press select. Ive tried changing printer setting and cant seem to fix it..
change the paper type at the printer to plain letter, or in printer properties from the start menu.
-Carl, please let me know if this helps.
Jun 25, 2009 | Office Equipment & Supplies
I have the unlocking code for nokia 5800, how to type in handset
There is your unlock instructions for your Nokia Phone... Enjoy :)
***** DO NOT enter the unlock code more than 3 times on BB5 phones, if you do you will NEVER be able to unlock your phone by code *****
1) Power ON your phone
2) Type #PW+CODE+1# using your keyboard
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
3) The phone will show "SIM Restriction Off," in case it doesn't unlock the phone, you will have to replace step 2 but use 7 instead of 1
4) Device is now unlocked
*** IF THE CODE IS REJECTED, DO NOT TRY AGAIN. ***
Substitute the 1 at the end with 7.
So 2nd time try: #PW+YOURCODE+7#
ie. #pw+000000000000000+7#
The letter P appears after you quickly press 3 times the button star ( * )
The letter W appears after you quickly press 4 times the button star ( * )
The letter + appears after you quickly press 2 times the button star ( * )
The phone shows "SIM Restriction Off" and is unlocked!
May 31, 2009 | Nokia 5800 XpressMusic Smartphone
The Samsung disc supplied will not load onto Vista
i just want to say thanks for the help in sorting out my samsung problem regarding connecting my g600 phone to samsung pc studio it worked first time
in phone type * #52828378# into phone and this appears
1 trace settings
2 ota type settings
3 serial test
4 tfs reset
you select 3 serial test
then this comes up
1 ppp up
2 serial download
3 run tck
you select
2 serial download
the phone will reboot connect you usb lead and pc studio will work
Feb 18, 2009 | Samsung SGH-G600 Cellular Phone
Install games on samsung D900, says unsupported file format
YA!!! guys calm down i 2 had this problem and sorted out in few days now follow the steps ok
1.Download Both Jad And Jar Files of the same game and place it in a folder (both files should be placed in a same folder).
2.Download Softick PPP i have provided you the link but remember you must have a bluetooth device or a usb with you here`s the softick ppp link download from here
http://www.soft32.com/download_157361.html
3.Now Download the uploader from http://www.4shared.com/file/29023658/99133c90/Uploader.html
4.now what you need to do is connect your mobile phone with the Softick PPP firstly activate the PPP by right clicking it and then ACTIVATE it`ll search your mobile phone accept its connection and leave your mobile phone
5.now open the uploader and upload the JAD file of the game and slide up you d900 screen and write this code
# * 5737425#.
6.Now it`ll give you 3 options select PPP UP and Go For USB if you have connected your phone through a USB or Click Bluetooth if you have connected your phone through Bluetooth.
7.It will return back in the same interface where you get three options there you should click on SERIAL DOWNLOAD and your mobile starts installing the game.
8.Now Repeat these steps but donot select again PPP UP TO USB OR BLUETOOTH remove this step and when you`re installing again the same time click SERIAL DOWNLOAD.
THANK YOU
Mar 16, 2008 | Samsung SGH-D900 Cellular Phone
Application intaller on samsung E250
انا عايز ثيمات لتليفونى samsung e250
Feb 08, 2008 | Samsung SGH-U600
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
85 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
