Question about Epson Stylus Pro 7800 InkJet Printer
I purchase a print head from Epson. I put it on by myself, did a power cleaning. But two inks doesn?t print out while I am doing print head testing prints. And then i did some head cleaning by using the utility, a few times. Two inks still don?t go through.
If you go back to the utility, are you able to confirm that the ink levels for all cartridges are not empty? If so, which are the two colours that do not print?
Posted on Jul 02, 2009
The head cleaning cannot be completed by the printer?
Epson printers use a lot of ink to do head cleaning. If you're low on ink, it will give you that message. Put in new ink carts, and head cleaning will happen. You may want to purchase "cleaning carts" that have a special solvent to help un-clog the print heads.
Sep 11, 2014 | Epson Office Equipment & Supplies
Epson tx700w black ink doesn't printing well.
1st a fall u must purchase original cartridge 2nd clean the head 3rd print the alignment page.
Be careful when u clean the head.
It is better if you use contact cleaner for head cleaner.
IN SHA ALLAH the problem will
Oct 06, 2017 | Epson TX700W Series
Epson 9800 ink magenta not printing after power cleaning
The separate print head is to blame. Needs replacement. Not cheap.
Aug 31, 2017 | Epson Stylus Pro 9800 InkJet Printer
Magenta nozzel is blocked how can i remobe this problem i have purchased epson r230 printer please tell me tha solution. best Regards ...
First try cleaning the print nozzles to see if this will remove the blockage. You can find the clean print heads option by pressing the menu key on the printer and then use the arrow keys to go through the choices until you see maintenance then press enter or ok. Continue to scroll using the arrow keys until you see clean print nozzle and again press ok or enter. Follow the prompts to use the clean print nozzle option a couple of times, then try another test page to see if this solves your issue. If it doesn't solve the problem and you still get the error that the nozzle is blocked, then open the top of the printer to get the ink cartridges to come to the center position (so that they are accessible) then turn off the printer and unplug it from the wall. Press and hold the power button for 30 seconds or more then open the top of the printer to access the printer cartridges. Remove both printer cartridges. Under the carriage where the cartridges are held, there should be a plastic hatch with a thumb hole to press and open this area. This is where the ink nozzles are located. They look like a sponge on top of an ink well. Get a couple of lint free cloths or rags and a wash rag with warm water and a few q-tips. Remove the ink wells and check for ink spill behind them that might be blocking the brass computer terminals. Scrape or wipe off any ink that you see in this area. Put the wells back into the printer and press the sponge top to make sure that they are wet and well lubricated. Make sure that the ink does not drip around the well when you press the sponge on top. If it does then clean it up again. Replace the cartridges and plug the unit back in, run another clean nozzle test and align the printer (printer alignment is available in the same area as the clean the print nozzle test is) then run a test print. If the error has not been resolved then there is nothing more that I can do for you without seeing the machine in person. If this is the case then contact Epson at www.epson.com on the internet for repair or replacement.
Jul 04, 2011 | Epson STYLUS R230 InkJet Photo Printer
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
I purchase a print head from Epson. I put it on by myself, did a power cleaning. But two inks doesn?t print out while I am doing print head testing prints. And then i did some head cleaning by using the...
Jul 02, 2009 | Office Equipment & Supplies
HI THERE
THERE ARE FEW THINGS RELATED TO YOUR SITUATION.
  1. THE INK CARTRIDGE DOESNT PROPERLY FIL IN THE STAND
  2. THE SEAL OF THE CARTRIDGE IS NOT REMOVED
  3. THERE IS A PUSH ASSEMBLY WHICH PUSH THE POINTS FOR SPECIFIC COLOR.MAY BE THT ASSEMBLY NOT WOORKING
  1. THE BEST SOLUTION TO YOUR PROBLEM WOULD BE THAT YOU SHOULD CALL THE CUSTOMER CARE AND THEY WILL REPLACE OR REPAIR YOUR PRINTER IF IT IS UNDER WARRANTY.
THNX
Jul 02, 2009 | Epson Stylus Pro 7800 InkJet Printer
JUST REPLACED INK CARTRIDGES ANDPRINTING IS JUST NOT RIGHT.
To carry out a nozzle check turn the printer off, then press and hold the Ink (looks like a droplet) button and the Power on button for about 3 seconds. The printer will turn on and print a test pattern. It also shows how much ink is left in each cart. All the lines should be continuous in each colour, any gaps mean that the print head nozzles need cleaning. To clean the nozzles press & hold the ink button for 3 seconds. If badly clogged it may require four or five cleans, leave for about ten hours and do another set of cleans. If still clogged you may need to purchase a print head cleaning solution such as can be found here:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
To carry out a head alignment download the quick guide and users manual from the Epson site:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58606&prodoid=56291067
Hope this helps, please take a moment to rate this solution, thanks.
Mar 20, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus Pro 7800 InkJet Printer Logo
135 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
