SOURCE: my jacuzzie motor just clicks and won't turn on.
If the GFI is good, pull the hose off of the pump and have someone push the button at the same time you have your finger over the end of the hose. If there is pressure at the end of the hose, the button is good. Put the hose back on the pump, and have someone push the button, you should hear a clicking each time it is pushed. If this is the case the internal switch in the little black box on the top of the pump is bad, they are avaliable from Guillens, it is called an air switch. Two screws secure the box cover and a nut on the outside of the box secures the switch, be sure to unplug the pump before working on the switch.
SOURCE: where do I find a magic touch whirlpool on/off
Go to Jacuzzi.com and find the part number, then go to Guillens.com and find the part you need.
SOURCE: I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
SOURCE: Our Jacuzzi Espree 6060 corner whirlpool stopped
You dont't need tp install your air switch anywhere until you find out if it is the problem. Simply connect it to the airline that activates the motor and push the button, If it works then it was the switch all along. If it doesn't, the the problem is with the switch on the motor or the motor itself.
SOURCE: I have a Jacuzzi Whirlpool Bath (Torino model)
The Magic Touch control has been discontinued now for some years. You will need to remove it and install a control that will have it operate with an air switch/air button system. This is a pretty simple fix but will run you right around $70 for an Air Switch Kit.
US Parts Center
