Question about Peavey Pv 2600 Power Amplifier
Power supply problem
Peavey 2600 Amplifier
i have a peavey 2600 the transformer got damageby water it was recoiled but some how the wiring got mixed up from me i don't have a service manual
  • Anonymous Mar 16, 2014
    the transformer is gone
  • Peavey Master
  • 5,603 Answers
Use the series light bulb trick when trying to first power this up. Use a 150 watt bulb in series with the 120 volt power to avoid damage and blown fuses.
Posted on Aug 28, 2009
Hello good morning i have a peavey 2600 power amplifier, each time i try to turn on the amplifier the breaker switch flies what could cause that to happen
A serious power drain caused by a damaged mains transformer, short circuit power supply, shorted output transistors or a leak to earth taking the earth treip out.
Mar 22, 2018 | Peavey Music
Wiring diagram
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Jan 12, 2014 | Peavey Pv 2600 Power Amplifier
My 2 pv 2600 amps have the same problem.all toroidal transforsmers busted.no smell or signs of over heating or over used.i found a cut or open wire on the windings.what causes the cut or open to the...
Mis-handling is the usual cause of this. This can also occur if the clamps don't hold and the transformer slides around. OFTEN you can splice in a short piece of magnet wire to repair these. Splice and insulate well.
Sep 29, 2010 | Peavey Pv 2600 Power Amplifier
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
I need a solution to repair peavey pv 2000 power amplifier.
Your best bet is to request a service manual from Peavey itself. These are usually available for around $20 or so. Call Peavey and ask for the service parts department and make your request there. They are very helpful and should be able to assist you.
Dan
Jul 11, 2010 | Peavey Pv 2600 Power Amplifier
No output on the right side of the peavey 2600 amplifier but the right is ok
Each channel is protected separately. I suspect that the outputs are fried on the right side or the output fuse has blown. This should be checked by a service shop.
Dan
Jul 15, 2009 | Peavey Pv 2600 Power Amplifier
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
Circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
Jun 24, 2009 | Peavey Pv 2600 Power Amplifier
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
244 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
