Question about Sony RM-Y135 Remote Control
Volume and channel up and down doesn't work
My remote control doesn't work .The red light on the tv button on the remote on the second line stays on at all times. I replaced the batteries and it still stays on. I can't change the channel or the volume. This tv was just given to me and when I first turned it on it worked until I tried to use the channel up and down button. Now it wont even turn it off.
ricomun
  • 24 Answers
SOURCE: SONY Remote Control - some buttons do not work.
Usually this means the conductive contact on the back of the rubber pad has worn down and cannot connect the circuits on the remote controls main board. There are several ways to fix this.
#1 Find some conductive adhesive or paint and carefully paint the back of the button tab ( let dry completely)
#2 Rear window defogger kits are available at most reputable auto parts shops and contain a paintable adhesive which you can apply to the back of the remote control button.
#3 try super gluing a small piece of aluminum foil to the back of the button tab.
I have used all 3 and they all work good.
Posted on Jul 02, 2009
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
  • 244 Answers
SOURCE: remote control AVOL ARC-l07 just suddenly stop
try replacing batteries!
good luck!
Posted on Oct 08, 2009
SOURCE: Sony RM-ASP001 for 400 disk changer stopped working
Our remote had been not working for a few months.
Today, in another attempt to either price a cheaper replacement or a fix, I happened upon this site.
I tried the series of fixes offered on this page, with no success.
On a whim, I decided to try the 3 position switch in the alternate positions. I figured I had nothing to lose if the remote was truly broken. I tried position 3 with no success.
I put the switch in position 2 and tried it and it WORKED!
Posted on Feb 05, 2011
joeguest2
  • 2080 Answers
SOURCE: All the buttons on my
Your remote control's internal button contacts on the circuit board may just need cleaning. If there is some residue, or debris, or oxidation inside on the surface of the circuit board it may be interfering with the correct operation of only a few buttons in particular.
It does not sound like a battery connection issue or a bad transmitter since most of the other buttons work fine.
You can try unscrewing, and disassembling the remote control in order to access the contact pads on the circuit board.
First check if there are any screws holding the remote control halves together. Be sure to open up and look inside the battery compartment as well. Once all the holding screws are removed, then gently pry the two halves of the remote control apart.
Use a cloth or a paper towel and some Isopropyl alcohol to clean off the surface of the circuit board and the underside of the button pads. Now check the circuit board for any signs of excessive wear, cracks, or oxidation on the copper contacts. You can use a pencil eraser to gently polish the copper contact pads on the circuit board if necessary. Once the unit is cleaned, just reassemble it and replace the screws and then try it out.
If you did see any significant damage inside or cracks in the circuit board, then you are probably going to have to eventually replace the remote. A wide variety of universal remotes to suit your needs and budget are available at any decent electronics store.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Posted on Apr 04, 2011
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
I lost the code to the ge universal remote jc024
hi...
From this website you can get the for your remote
http://www.jascoproducts.com/support/universal-remote-codes.asp
follow the steps to set up the remote
Method 1
Step 1: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 2: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink, then stays lit.
Step 3: Enter the 4 digit code for your device. After a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes!
Step 4: With your device on, press "CHANNEL UP" or "CHANNEL DOWN." If the device responds, no further programming is required. If some buttons do not operate your device, try one of the other codes for your brand. Note, when all codes have been searched the red indicator flashes rapidly for 3 seconds.
Code Search instructions
If your device does not respond to any of the codes listed with your equipment, or your brand is not listed, try the following steps:
Step 1: Manually turn on the device to be controlled.
Step 2: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 3: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink once, then stays on.
Step 4: Press the "CHANNEL UP" button repeatedly until the device to be controlled changes channel. The red indicator will blink, then stays lit.
Step 5: Press and release "MUTE" button to install the code. The indicator light goes off.
Jul 20, 2010 | Universal Remote Control GE174Universal...
TV doesn't turn on
I have a Mintek DTV265 which is almost the same TV the red light don't blink it stays on as long as the Power button is on. Try turning on the TV by pressing any of the buttons on the side of the TV Channel up or down, Volume up or down , or source. If it comes on then your TV is alright. I had one of them jumbo universal remote controls and it actually had a code that worked on my TV.
Mar 02, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
The code to programm my philip universal remote with my toshiba television
code and instructions can be found type phillips remote codes into search bar and choose a website
or press and hold code search button till red light stays on then enter each 3 diget code untill the tv functions codes for toshiba 112 313 413 506 510
512 613 902 after correct entry red light goes off
try channel up down volume after each code good luck ron
Dec 10, 2009 | Philips Universal PH301S Remote Control
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
Need to how to set remote philips TV an DirecTv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
these steps will set up the first device and then to set up the second device just repeat the steps choosing the other device and the code for it.
CODES: for the tv: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0019,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
for the direct tv: 1049,1766,1767,1768,0622,0632,0629,0623,0576,0586,0616,0613,0630,0634,0636,0638,0641,0652,0653,0657,0659,0607,0619,0537,0538,0539
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Philips Magnavox Learning Universal Remote
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  1. Manually turn on device to be controlled.
  2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
  5. Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
  1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
  2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
  3. Press and release the "Code Search" button. The red indicator light goes off.
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
  6. Repeat again for the third digit in your code number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Remote not working on TV
Try programming with Code Search:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 13, 2008 | Philips Televison & Video
How do i!
make sure the batteries are good and installed correctly. turn on device(manually) press and hold (setup) button until the red indicator stays on. then release the set up button. press and release device button(tv,vcr ect) the red indicator light will blink, then stay lit. press channel up until the device changes channel.The red indicator light blinks and stays lit.if you over shoot the code required press channel down to back track. now press and release the mute button to lock in the code.
Jan 13, 2007 | GE RM24912 Universal Remote Control
Sony RM-Y135 Remote Control Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
