Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Dishwasher accumulates water
I have disconnnected the water source and there is no new water in the bottom, so it have been the valve.
B where is the valve located? Do I have pull out the dishwasher? I guess if it's hard to fix or I have to order it from the manufacturer instead of using a generic part, I might be better off asking someone else to do it.
Here is my original questions:
My Whirlpool dishwasher washes and drains fine, but accumulates water when it is off. It takes about one day before the bottom part of the dishwasher is filled up with water. It is clean water. My guess is there is probably some problem with a valve, so even though the dishwasher is off, water continues to flow into it.
Still need a solution for this problem?
Try our Premium Assistance plan Best Solution posted on Nov 09, 2007
By Amigaman
Rank: Master
Rating: 78.75%, 32 votes
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
  • 76 Answers
Your valve will be on bottom but they are sometimes not to hard to get to also you do not have to change the valve some of those selanoid valves are expensive and the do make seals and or o-rings to fix those valves i fix them quite often the only time you have to change the whole valve is when the selanoid burns up if you can give me the serial and model #s plus brand and make i may be able to find out what we need to do to get you leak free with out breaking the bank
Posted on Jun 29, 2009
VERY LOW WATER PRESSURE TO THE LOWER AND UPPER SPRAY ARMS. FILLS AND EMPTIES NORMALLY
Hello there:
i will post this solution in 2 separate post due to the length of it ok
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
ools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home's electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
Oct 16, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
My dishwasher isn't taking in water, i've checked that the water is switched on and my inlet hose is not blocked, any ideas?
You don't state a brand or model number, so this is a bit generic: Look for a float switch which may be hanging up from accumulation of gunk on it. (generally an upsidedown plastic can shaped thing on the bottom of the dishwasher tub. (you have to take the cover off to get to the float) Another possibility would be a bad water inlet valve. (electrically open coil on valve)
Feb 07, 2010 | Dishwashers
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
Kenmore dishwasher is not washing properly and leaving dirty water in the bottom when it is finished, Can i fix it?
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jun 02, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag Quiet Series 200 Dishwasher Leaking Internally
two possible sources of water
either
inlet valve leaking. turn water off after use and if no water accumulates, then cause is leaking valve
or
if drain is plumbed in to a spigot on the sink trap, then every time you empty water from the sink, some of it goes down to the washer
cure by taking the drain hose up as far as possible under the sink in a swan neck
Oct 12, 2008 | Maytag Dishwashers
Subject is Bosch dishwasher SHU6800. There is a soap residue left on dishes. Residue is not visible. Using two glasses taken from a recently completed wash cycle I rinsed one under tap water and then...
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Aug 17, 2008 | Dishwashers
Dishwasher Accumulates Water When Off
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
WATER IS RUNNING EVEN WHEN IT IS OFF
yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Nov 07, 2007 | Bosch SHU4006 Dishwasher
Water in bottom of dishwasher
Hi You have a drain problem, Your house drain may be restricted the dish washer pumps out with more pressure then the water just falling down your sink.I would snake it or have a plumber clean out that drain...let me know if this helps krazytech
Aug 24, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
201 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
