Question about Garden
I just went to start up my older model McLane gas edger. Started up without a problem until the spark plug suddenly flew out. I assume I must need a new spark plug but is there more?
  • 155 Answers
I would check the thread where your plug screws in it can be fixed with what they call a helicoil thread repair kit hope this helps.
Posted on Jul 25, 2009
What can be making my edger turn off right when it sounds as though its going to start?
A faulty on off switch can cause this.spark plug foulage.fuel blockage.loose spark lead.broken power feed to spark.hope this helps
Aug 14, 2014 | McLane 3.5 HP Gas Edger & Trimmer...
I have Homelite trimmer/edger for 3 years. It has been working great until recently, after a cold start and edging for 7 - 8 minutes it stops all of sudden until it gets cold and runs for 6 -7...
You need to check the ignition coil, by running until it quits and then remove the spark plug, reattach the plug wire and then ground the plug threads to the block and then try to start it. If you get no spark or very weak spark, the coil is bad and needs to be replaced.
I hope this helps get you going again.
Aug 17, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a TROY-BILT Tiller/Edger model 12216. I installed a brand new spark plug, fresh gas and new oil. It started and I even used it to break up a small portion of my yard. By small I mean probably 5...
check gas/oil, if all is good the pull the spark plug, hook the spark plug back up and pull the cord while observing the spark plug for spark, may be the coil. Hope this helps Tim
May 02, 2011 | Garden
Can not start garden edger made by mclane
O-kay engine and motor are the same. I'll have to do some checking on this one and I'll get back to you.
Oct 02, 2009 | Garden
2-cycle toro weed wacker does not start
Sounds like the flywheel has come loose and sheered off the key which locates it on the crankshaft without this the timing will be out ,
Jul 17, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Garden Logo
218 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
