Question about Samsung Televison & Video
50inch plasma top half of screen becomes black or top half looks like a test pattern any thoughs
    Problem Solver:
  • 5 Answers
Look at the screen menu. And try to reset it to factory settings.
Posted on Jul 02, 2009
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I own a LG50PG30 that once the TV becomes warm, develops a 2inch black vertical line through the right side of the screenfacing the TV which contains a 1.5inch white line through it and has multiple c
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 05, 2015 | LG Televison & Video
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
Horizontal half black screen, sound is still there
A plasma screen uses thousands of tiny fluorescent bulbs in different colours (red blue and green) to produce a picture. Just like standard house hold fluro lamps, these tiny bulbs use starters to turn them on and off. As there are so many bulbs in the panel and therefore starters, the panel has a number of "starter controllers". These controllers can control anywhere from a quarter up to half of the screen. If a controller dies, it takes out it's segment of the screen. Unfortunately, it sounds as if this is what has happened in the case of your LG - this is also common in NEC and Fujitsu panels. Althought these controllers can be fixed, it usually takes more time and money than it's worth- unless you have it under warranty in which case the manufacturer will just replace it. Sorry top be the bearer of bad news. hope it helps
Jul 06, 2009 | LG 42PC3D 42 in. Plasma Television
Hey i have a phillips 50inch plasma tv and recent the bottom half of the tv goes black... what wuld u think the problem is??
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Philips Televison & Video
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
RCA PHD50300 no picture on top half of screen
Replace the scan drive board also called X-sustain board. This is the board on the upper left side in the back of the set with a huge heat sink on it. you can find them online for about 175.00. The p/n is pkg50c2g1. Be carefull with the 4 ribbon connectors that go to the display.
Apr 03, 2008 | RCA Scenium PHD50300 50 in. Plasma...
Lg 50inch tv(lg50px4d-eb
check with your service provider they be able to help you.good luck.
Apr 08, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
