Question about Viking Dishwashers
Viking dishwasher fills then goes into drain I checked and it is not leaking
  • clayton winklepleck Jul 02, 2009
    kevin thanks for the help . it will b next week before I will get back to this customer .will I still b able to chat with u .about this
    President:
  • 942 Answers
Hi...
Just check the you dishwasher try to do this,,
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assemblt
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
Good luck!!!
Regards
PCmania
Posted on Jul 03, 2009
    Genius:
  • 1,847 Answers
There is spring located on the plunger to bring it back up closed this sound like it has fallen it is very small about 1 inch long if the d/w drains still and plunger is up there is a plastic and rubber flapper in the pump that operates water release function there is a rubber stop in this in the center that somtimes dis lodges leaving an open hole that will allow water to seep out it is not related to your drain hose at all thanks hope this helps
the only way to see is to remove motor and inspect drain flapper any sort of rubber plug or grommet that will fit in it securely will work im not sure if you can order rubber plug seperate if there are any used appliance or parts store
around you they might have an old motor that is bad and the rubber stop would be in it The motor is held in by 1 arm bolted to the or motor hangs off an arm and the 2 boot clamps from the tub good luck
Thanks
K
Posted on Jul 02, 2009
LDF7932ST leaks while filling
Has anyone checked the drain hoses inside the machine. My LDF7932 dishwasher was doing the same thing and it turned out to be one of the drain hoses had a crack that was leaking causing a short in the wash motor and a leak in the machine--hope this helps.
Good luck
Nancy
Dec 19, 2012 | LG LDF7932ST Builtin Dishwasher
Viking dishwasher float valve location
Hello, welcome to FixYa.
Based on your post I understand you have a Viking VUD141 dishwasher, correct ? I also interpret your post as you are trying to locate the float, correct so far ? (there is no "valve" present for the float)
As you may or may not know these are built by Asko (AM appliance group)...that being said, the float is located under the tub behind the toe plate.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base...it should be known that if you leave the unit for a few days, the water (if present) in the base will evaporate hence appearing as everything is fine again...if a problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
Your Viking will be slightly different, but likely only cosmetics. Once you've located the float behind the main connection plate, you should see something like this image below, i.e.
**Top arrow is the switch identifier, the second is the actual "float" ** With the aid of a long screwdriver or if you can reach it, move the float up and down and listen closely for the switch to "click", indicating it is indeed functioning.
The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit to service or call for service to the unit. the first is the "pressure switch. It controls fill as well as "over-fill" scenarios.
That's the extent of accessing the float assembly. Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Oct 22, 2011 | Viking 24 in. Professional Series VUD141...
Dishwasher is stuck in one cycle and will not go to the next. I believe it may be the drain cycle. Turning the knob does not help. A year or so I experienced the same problem which I believe may have...
Most Viking models have overflow safety feature that turns the dishwasher into drain mode. The idea is to remove overflow water from the bottom pan. Check the pan behind kick toe panel for water, remove the water and check for leaks. If no water check overflow switch somewhere in the pan, it maybe stuck. Good luck
Jan 24, 2018 | Viking 24 in. Professional Series VUD040...
I have a Vikin Dishwasher Model DFUD042 and the arms are not circulating water. When we start a cycle it drains previous water then fills it up after that it runs thought its regular cycle but the arms are...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
42gda
Apr 21, 2010 | Viking 24 in. Professional Series VUD141...
The pipes froze in my house and now the dishwasher seems to work (ie it all sounds fine and water is in it), BUT it leaks badly. viking model vud140.
If the temperature dropped in the home too the water retained within the pump and the units lower assembly may froze which may have cracked which woul leak heavily. It mat be by chance too that the seal within the pump has failed. If it leaks only when the pump runs chances are the seal may be out; if however it leaks with nothing running it may be a crack. Another spot to check is the fill solenoid. You need to get underneath it or pull it out to determine where the leak is coming from.
I hope this may have helped,
Tom
Aug 22, 2009 | Viking Dishwashers
30 yr old Viking dishwasher leaks...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
tyue56
Aug 06, 2009 | Viking DFUD04 Built-in Dishwasher
My Viking just stopped providing water - it goes through all the
You probably have a leak, in the pump housing area below the unit, which is causing the drain pump to run continuously.
Jan 26, 2009 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher won't fill with water
NEED TO CHANGE THE ELECTRIC TAP IN THE BACK OF THE DISHWASHER.
THE TAP IS WHAT THE WATER HOSE CONECTS TO AT THE BACK OF THE MACHINE.
Oct 14, 2008 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher
Probable cause is either a bad fill valve, common with these, or just some debris in the fill valve inlet screen, also common. If you are handy you can take apart the fill valve and check the screen but often one needs to replace the whole valve, about an $80 part + labor. Double check your valve under the sink and make sure it is on completely.
Apr 30, 2008 | Viking 24 in. Professional Series VUD040...
Eaton viking dishwasher
it may not be the pump.if it leaks when you run a wash cycle then the pump seal may be bad but if it only leaks when you drain it,it seems that its a drain hose/piping connection.
Nov 03, 2007 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
