Question about Kenmore 9446 Range
The breaker tripped when I turned the oven on. When I reset the breaker, the range beeps, the door locks, and F1 code appears in the display. None of the control buttons work, however, the top burners work okay. What should I check?
    Problem Solver:
  • 8 Answers
Sounds like the Oven temperature probe has failed.
Posted on Jul 03, 2009
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Error Code F1 on oven timer panel
I have the same problem as above. Is there any quicker way to get an answer from tech support. I have no stove or oven right now.
Sep 05, 2008 | Kenmore 46123 Stainless Steel Electric...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
F1 Code on display
The model # is incorrect...please post correct m #....
Aug 27, 2007 | Kenmore 94223 Electric Kitchen Range
Electric Range Door Locked after cleaning
"F1" is an error code for any of the following possible problems: Electronic Oven Control (EOC) board. Wiring harness shorted. Defective touchpad on the control board. I speculate that the control board may have failed during the cleaning cycle, causing your problem. Unfortunately, this may be an expensive repair if it is a control board, and it could be maintenance intensive to get to the door latch to release it. You will need to lift the stove top to gain access to the linkage for the oven door relay. There should be a few screws under the top front to remove. Make sure you unplug the unit or turn off the circuit breaker before servicing. I hope this helps you.
Jul 28, 2007 | Jenn-Air JER8850 Electric Kitchen Range
F1 and constant beeping
Tul2pi, there are several things that could cause this. 1. shorted keypad. If you unplug the keypad ribbon from the board and the beeping stops it's more than likley your problem. 2. Temperature probe in the oven may have gone bad. You would have to ohm this out. At 75 degrees it should read approx. 1091 ohms. 3. Worst of all it would be a control problem itself where as you would have to replace the control board. Since you are so close to the warranty period, I would call Frigidaire at 1800-944-9044 and see if they would cover it...Catriver..post back.
Aug 29, 2006 | Frigidaire PLES389D Electric Kitchen Range
Kenmore 9446  Range Logo
287 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
