I just bought a USED SAMSUNG MODEL HLN507WX/XAA.I connected the HD Box from Comcast and it indictes "Not Supported Mode" when using Component-3 inputs. It worked fine at the previous owner's home. He had the old type Comcast HD Box.I had it working for a while then the screen would begin flashing and state again "Not Supported Mode."Comcast can't seem to fix the problem over the phone.Any Ideas?Willie
Comments:
Oct 31, 2009
- Change to the new Comcast box.
After changing, turn on the box and wait 20 seconds for it to download.
Then, on your remote,press "Cable", then "Power", then Menu.
You will see the settings menu. Set the primary value to (1080i)
and the override reading to (480p).
The above is what I had to do to get it to work.
You can play with the settings if that doesn't work, however the new box is 1080i. The old box is 720p.
After you complete the settings, press "Power" and then select your connection on the TV remote.
Hope this solves your problem
Have a great day
across the bottem of the the screen theres a black 2 inc strip it look like the pic needs to come...
(More)
across the bottem of the the screen theres a black 2 inc strip it look like the pic needs to come down how can i adjust it
I have a Samsung HLN5065W DLP TV that the display freezes in B&W and has to be cycled on/off...
(More)
I have a Samsung HLN5065W DLP TV that the display freezes in B&W and has to be cycled on/off to get the picture back. This problem is getting progressively worse. Sometimes the display will just turn dark blue and has to be cycled to get the picture back.
