Question about IBM Lexmark Z715 InkJet Printer
The cartridge is moving like it is printing. But
The cartridge is moving like it is printing. But the page coming out is blank. It's like the cartridge is not sitting low enough to the paper. But it worked fine yesterday.
  • 750 Answers
Make sure that the ink cartridge is full and is securley snapped into place. If you have alreayd checked that then chances are the printing head of your printer is damaged or the motor that move sthe printing head is damaged. Call the manufacturer and demand that you get a replacement printer (asumming that the one you have is under warranty).
Posted on Jul 02, 2009
Hi, thanks in advance for any solution suggestion. My xerox pe 220 prints blank page. Cartridge is new. Th poblem should be with the driver, installed it several times, but it doesn't help. Can anybod
Does it sound like it's trying to print or does it just quickly spit out a blank page. If you print something three pages long, do three blank pages come out??
I know this may sound silly, but did you remove the piece of tape that covers the contacts on the new print cartridge?
Nov 25, 2013 | Xerox Computers & Internet
Have tried printing from computer and tried printing test page from printer. both times the pages come out blank.. how do I check the toner levels in printer. thank you
The draw back of inkjet technology printers are, if it is not using quite long period of time,cartridge nozzles will dry up, result printer will act just like a printing some thing but nothing will come on paper(blank page) even ink levels are showing full.
Try to recover the both cartridges through 'clean print cartridge' process from the system,if not better consult cartridge re-filler to clean the nozzles..Replace new cartridges if above said methods are not worked out.
Nov 10, 2012 | HP PhotoSmart 7760 InkJet Printer
We understand that your problem is: Sir, iam jithesh from india,kerala.I have one printer samsung ml1210 printer .give the one print blank page coming automaticaly picking second papper blank page coming...
hello ,
first check your toner cartridge. some time your toner cartridge is damage then black print out is coming.
then check your machine printer and faxes ,check print pages status.sometime their have early print outs.
didnt solve your problem you have to replace main board
Jan 18, 2011 | Samsung ML 1210 Laser Printer
Prints blank pages
check if there is still ink in the cartridge.also use a soft cloth and little water to clean the nozle of the cartridge.
Jul 02, 2009 | Epson Stylus C62 InkJet Printer
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer output is a blank page
hi,
* Please check with the ink level in the Catridge.
* Be sure that catridge nozzle is not dry or dirty.
* Check wheather ink nozzle is clogged/ damaged if so use rubbing alcohol to clean them.
* Try printing by replacing new catridge.
Thanks,
Appereciate to rate as "FixYa"
May 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Printing blank pages, cannot detect any problems in maintenance
Sounds like your printhead is clogged, see posts in my profile for clearing out stubborn clogs.
Jan 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
IBM Lexmark Z715 InkJet Printer Logo
236 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
