Question about Exercise & Fitness
Incline does not work on my NordicTrack APEX 6100 Xi. Any ideas on the problem?
  • 14 Answers
SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
Posted on Jul 08, 2009
  • 40 Answers
SOURCE: I have the Nordictrack Apex 4100I treadmill. It
try caibrating it.
Posted on Nov 01, 2009
  • 42 Answers
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Posted on Nov 21, 2010
2manyhobbies
  • 129 Answers
SOURCE: on my nordictrack a/2350 the incline stoped
Follow the instructions found in your manual for incline calibration first. With the safety key/magnet in, press incline up, remove the key while the numbers are changing, release the incline button then reinstall the safety key. The incline should calibrate.
If the motor moves, then stops b4 completing it's cycle, the incline sensor may be defective. The sensor is the black cap/wire coming out of the top of the motor. Make sure it is connected properly.
If the sensor is defective, you have to order the complete motor to repair the problem The sensor can be replaced without replacing the motor, but it is not available as a replacement part..
Part #249516 around $110....
Posted on Dec 15, 2010
2manyhobbies
  • 129 Answers
SOURCE: I have the EXP 2000 NordicTrack incline treadmill
Manuals can be downloaded at http://www.iconservice.com/CustomerService/manuals
First perform an incline calibration.
Insert the safety key/magnet. Press the incline up button. While the numbers are changing, remove the key. Release the incline up button and reinsert the key/magnet. The machine should go to the top and then back to the bottom.
If it only starts then stops, the incline sensor may be defective. Be sure all the plugs are secure on the controller board.
If the sensor is defective, you will need to order a new incline motor..
If the incline motor does not move at all, the controller may be defective..
Why does incline go up and down when you turn on treadmill?
The sensor or relay is stuck, it's an easy fix with electronic contact cleaner, if you can access the part's ?
Feb 21, 2015 | Nordic Track Nordictrack Apex 4500...
My incline motor stopped working on Nordic tracap apex5100
unplug unit and remove the motor cover. there are two bolts that hold the incline motor in. one on top of unit and the other on the bottom of the lifting screw. make sure incline is all the way down. follow the wiring to the control board. removed them off the board noting which ones go where and color orientantion. instillation is reverse of removal
Sep 04, 2014 | Nordic Track Nordictrack Apex 5100...
I have a Nordictrack Reflex Sr. The console turns on but the treadmill only runs when quickstart button 5 and 11 are pressed. also incline not working
1( Adjust the Reed switch, clean and tight the wires connector very well
see the diagram.
1A) Tight the ribbon cables from keypads very well, and clean
2) Run after you fix it the software calibration for diagnose and troubleshooting, and fix it.
See the block diagram
Jun 14, 2012 | Nordic Track Nordictrack Apex 6500 Reflex...
My nordic track apex 6100 xi all of the sudden won't run...or walk...at all? HELP!
Dear Sir:
This is probably a 1) faulty speed sensor or 2) the speed sensor is not plugged in properly. Its also possibly a 3)faulty motor control board or lower board.4)the drive motor is faulty 5) The drive belt is broken.6) Resent c.breaker 7) Test the power cord. 8) Reset the c. breaker from your home. 9) Do not use extension cord .
Adjust the speed sensor see the diagram, and RUN your software calibration for easy diagnose and troubleshooting. read your user manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 11, 2012 | Nordic Track NordicTrack Elite zi...
How do you reset the nordic track apex 6100 xi i paid a repair person $100 dollars to hit 3 buttons but now i can not remember. can you tell me what 3 button and in what Sequence
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline system.
Sep 13, 2010 | Sport & Outdoor - Others
Our Nordic Trac Apex 4100i will power up but the keyboard does not respond to different key presses and the incline is stuck part way up. We ordered a power supply and replaced the original one. That did...
You can try and do a re-calibration on the treadmill (Its listed in the Users Manual) but it sounds like the console has gone bad. To repair this you would have to replace the entire console.
Aug 21, 2010 | Nordic Track Nordictrack Apex 4100i...
Nortrak 4100i wont go up or down
hold down stop and speed + then put safety key on
hit stop once
push incline+
let it go up and down
take key off and reattach
try
if it still doesn't go the incline motor is bad
Aug 07, 2010 | Nordic Track Nordictrack Apex 4100i...
Reset programs
Hello there, If you go to iconservice.com you will be able to find a free downloadable pdf file there under the manuals section. Then select nordictrack in the brand and then put apex 6100 in the model name then do a search. You will see a list of manuals come up. Pick the correct model number. (located on the lower frame below the walk belt.)
Download and print.
There are instructions in there on the custom programs and how to set them up.
Good Luck! Tim
Jan 17, 2010 | Nordic Track NordicTrack Professional...
Nordictrack apex4100i level incline will not work
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
741 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
